January 13, 2011, 02:19 |
building MRFSimpleFoam
Rep Power: 17 |
Hi everybody.
I continue here another thread because a user defined my problem, so this is the right forum section. I installed OpenFOAM-1.5-dev from CAE Team PPA and I want to use MRFSimpleFoam. I was explained I have to build it into MRFSimpleFoam tutorial folder. I found /usr/share/doc/openfoam-dev-1.5/examples/MRFSimpleFoam/MRFSimpleFoam. It contains a subdirectory Make (with files and options files) and two files: MRFSimpleFoam.C and createFields.H. I tried wmake but it fails (not found). Maybe I have to run make? I use Ubuntu 10.04 64-bit. |
January 13, 2011, 17:49 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Maurizio,
Here's what you do: Code:
mkdir -p $WM_PROJECT_USER_DIR cd $WM_PROJECT_USER_DIR cp -r $FOAM_TUTORIALS/MRFSimpleFoam/MRFSimpleFoam . cd MRFSimpleFoam wmake Code:
sudo apt-get install openfoam-dev-1.5-dev Bruno
January 14, 2011, 01:38 |
Rep Power: 17 |
Thank you, Bruno. You're always helpful.
Solar Radiation in OpenFOAM | plainstyle | OpenFOAM Running, Solving & CFD | 15 | July 8, 2014 04:43 |
MRFSimpleFoam Tutorial | bastil | OpenFOAM Running, Solving & CFD | 48 | August 1, 2012 10:00 |
ParaView 3.8.0 problem on debian | Unseen | OpenFOAM Installation | 4 | August 16, 2010 10:26 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 04:55 |
Building error with simpleSRFFoam and MRFSimpleFOAM in 15 | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | August 27, 2008 10:31 |
