January 5, 2011, 22:47 |
Building ThirdParty from OpenFOAM-1.6-ext
Chris Sideroff
Rep Power: 22 |
I was attempting to build the ThirdParty stuff in 1.6-ext on my Ubuntu 10.10 workstation last night and stages 0-3 went fine but it skipped over stage 4 stating "Using system installed QT".
So I looked in Allmake.stage4 - lines 60-66 are the following: Code:
if [ ! -z $QT_THIRD_PARTY ] then ( rpm_make qt-everywhere-opensource-src-4.7.0 http://get.qt.nokia.com/qt/source/qt-everywhere-opensource-src-4.7.0.tar.gz ) else echo "Using system installed QT" echo "" fi Or am I way off base? |
January 5, 2011, 23:32 |
Chris Sideroff
Rep Power: 22 |
I hate replying to my own threads but sure enough right after I posted I found an answer to my question.
In the $WM_PROJECT_DIR/etc directory is a file called prefs.sh-EXAMPLE. In there is where one tells the build what to do about QT (use system or build third party version). I just copied prefs.sh-EXAMPLE to prefs.sh, uncommented 'export QT_THIRD_PARTY=1' and then re-sourced the OpenFOAM bashrc file (the easiest way is just to close your terminal window and open a new one - assuming you have the OpenFOAM bashrc file sourced in a start up script like $HOME/.bashrc) |
February 23, 2011, 04:29 |
Building ThirdParty without connections to the internet
Stefan
Dear FOAMers:
I'm glad about integrate the ThirdParty-stuff within the OpenFOAM-<version> directory like in 1.6-ext. But my central problem is, that the linux machine that running OF don't have a connection to the www! Now i'm stucking with building the ThirdParty-environment. Is there only the possibility to download the needed tools hand by hand? Maybe there exist a ThirdParty-collection in the mannar of 1.6.x, 1.7.x, etc.? The ThirdParty-1.6.x doesn't worked for me as well as compiling 1.6-ext with my system settings. /Stefan BTW: OS is Debian Lenny 64-bit, additionally REHL DT 5.3 in future. |
install OpenFoam 1.6 by building source: how? | niudie | OpenFOAM Installation | 13 | April 26, 2011 00:48 |
OpenFOAM 1.6 and ThirdParty Software Paraview | dunlopjp | OpenFOAM Installation | 0 | February 24, 2010 11:35 |
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 7 | January 19, 2010 15:39 |
OpenFOAM 1.6 package - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 36 | September 2, 2009 12:46 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 04:55 |
