building MRFSimpleFoam
Old   January 13, 2011, 02:19
Default building MRFSimpleFoam
vaina74 is on a distinguished road
Hi everybody.
I continue here another thread because a user defined my problem, so this is the right forum section.
I installed OpenFOAM-1.5-dev from CAE Team PPA and I want to use MRFSimpleFoam. I was explained I have to build it into MRFSimpleFoam tutorial folder. I found /usr/share/doc/openfoam-dev-1.5/examples/MRFSimpleFoam/MRFSimpleFoam. It contains a subdirectory Make (with files and options files) and two files: MRFSimpleFoam.C and createFields.H. I tried wmake but it fails (not found). Maybe I have to run make?
I use Ubuntu 10.04 64-bit.
vaina74 is offline   Reply With Quote
Old   January 13, 2011, 17:49
Retired Super Moderator
Bruno Santos
Hi Maurizio,
Here's what you do:
mkdir -p $WM_PROJECT_USER_DIR
cd $WM_PROJECT_USER_DIR
cp -r $FOAM_TUTORIALS/MRFSimpleFoam/MRFSimpleFoam .
cd MRFSimpleFoam
wmake
And voilá, ready to be used. Note: I installed both the "openfoam-dev-1.5" and "openfoam-dev-1.5-dev" packages! Possibly you only installed the first one. Here is how you can install the second:
sudo apt-get install openfoam-dev-1.5-dev
Best regards,
Bruno
Old   January 14, 2011, 01:38
Thank you, Bruno. You're always helpful.
Solar Radiation in OpenFOAM plainstyle OpenFOAM Running, Solving & CFD 15 July 8, 2014 04:43
MRFSimpleFoam Tutorial bastil OpenFOAM Running, Solving & CFD 48 August 1, 2012 10:00
ParaView 3.8.0 problem on debian Unseen OpenFOAM Installation 4 August 16, 2010 10:26
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 04:55
Building error with simpleSRFFoam and MRFSimpleFOAM in 15 waynezw0618 OpenFOAM Running, Solving & CFD 4 August 27, 2008 10:31
