July 1, 2011, 16:39 |
updating OpenFOAM-1.6-ext
Chris Sideroff
Rep Power: 22 |
I thought I'd throw this out to the community before I log it in the openfoam-extend bug tracking system in case I'm missing something obvious.
I had previously built and had been using OpenFOAM-1.6-ext successfully (about 2-3 months ago) and wanted to update it to include some fixes. So I: Code:
$>git pull Code:
$>./Allwake Code:
make: *** No rule to make target `/opt/OpenFOAM/OpenFOAM-1.6-ext/src/meshTools/lnInclude/meshTools.H', needed by `polyDualMesh/polyDualMesh.dep'. Stop. Did the location of some files change but the necessary updates not make it into the dependency files? Or am I way out to lunch, my build tree got borked up somehow and should build from a clean pull? I'll include the full error log if/when someone asks for it. Thanks, Chris |
July 1, 2011, 17:14 |
Chris Sideroff
Rep Power: 22 |
Nm, I forgot to clean the source tree before rebuilding so all the old .dep files remained. It's been a long day ... ugh.
Test directory missing in OpenFOAM 1.6 ext | andrewryan | OpenFOAM | 2 | March 20, 2011 15:41 |
[swak4Foam] OpenFOAM 1.6 and 1.7 with interFoam, groovyBC give different strange results | Arnoldinho | OpenFOAM Community Contributions | 7 | December 9, 2010 16:29 |
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 7 | January 19, 2010 15:39 |
OpenFOAM 1.6 package - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 36 | September 2, 2009 12:46 |
OpenFOAM Version 1.6 Released | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | July 27, 2009 17:55 |
