Problem installing OF 2.0.1 on Ubuntu 11.04
Old   October 7, 2011, 15:12
Default Problem installing OF 2.0.1 on Ubuntu 11.04
Ricardo
rvmedina20 is on a distinguished road
greetings all,
I recently installed ubuntu 11.04 on my computer and i am trying to install OF, but i am getting some errors. Ive used ubuntu and OF, but i did not encounter any problems then. I am somewhat new to ubuntu/linux,
I am following the installation commands from here:
http://www.openfoam.com/download/ubuntu.php
After I run the >>sudo apt-get updates (it runs the update but at the end i get this message
W: Failed to fetch http://www.openfoam.com/download/ubu...-i386/Packages 404 Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
>>~$ sudo apt-get install openfoam201
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package openfoam201
I didnt ant to continue the installation commands, until i have fixed this. I would really appreciate it if someone can please, please help me. Thanks
-Ricardo
rvmedina20 is offline   Reply With Quote
Old   October 8, 2011, 08:22
Van de Leur is on a distinguished road
Ricardo,
For the first installation step, replace the term $VERS with natty, then the installation should work.
Enjoy!
Regards,
Kevin
Van de Leur is offline   Reply With Quote
Old   October 10, 2011, 19:50
Ricardo
Thanks, Kevin.
Looks like i was successful in the installation of OF! Thanks a lot!!!
cheers,
-Ricardo
Originally Posted by Van de Leur View Post
Ricardo,
Enjoy!
Regards,
Kevin
Old   May 22, 2012, 02:41
Question
Chen Xiaobing
xbchen168 is on a distinguished road
VERS=`lsb_release -cs`
sudo sh -c "echo deb http://www.openfoam.org/download/ubuntu $VERS main > /etc/apt/sources.list.d/openfoam.list"
I have similar problems.
sorry, do u mean to replace "VERS" with "11.10" ? What should I input for this VERS?
I installed "Ubuntu Desktop 11.10 desktop i386" system.
thanks.
Ricardo,
Enjoy!
Regards,
Kevin
xbchen168 is offline   Reply With Quote
Old   May 22, 2012, 16:01
Retired Super Moderator
Bruno Santos
Greetings Chen,
Can you detail what is the exact problem?
Best regards,
Bruno
Old   May 22, 2012, 21:13
Chen Xiaobing
thanks for the greetings.
HTML Code:
The problem is the same as following,
" I am following the installation commands from here:
E: Unable to locate package openfoam201 "
Pls advice. thanks.
Originally Posted by wyldckat View Post
Greetings Chen,
Best regards,
Bruno
Old   May 23, 2012, 07:15
Bruno Santos
Hi Chen,
OK, now I remember, run this modified command (in bold is the change):
sudo sh -c "echo deb http://www.openfoam.org/download/ubuntu natty main > /etc/apt/sources.list.d/openfoam.list"
This is because 2.0.1 doesn't exist for oneiric, so you have to try and use a version that was meant for another Ubuntu version.
But keep in mind that you might run into problems, since there might be some backwards compatibility issues, so you might have to build from source if those problems occur.
Good luck!
Bruno
Old   May 26, 2012, 05:52
Chen Xiaobing
thanks. it works now.
nice weekend.
Hi Chen,
Good luck!
Bruno
openfoam 2.0.1, ubuntu natty 11.04
2.0.1 istallation problem using icc fisch OpenFOAM Installation 2 October 9, 2011 10:17
OpenFOAM-1.6-ext on Ubuntu: frustrating problem marupio OpenFOAM Installation 0 March 10, 2011 11:28
Installing OpenFOAM 1.6 on Ubuntu 10.4 sda OpenFOAM Installation 5 May 27, 2010 20:19
Trouble with installing OpenFOAM on Ubuntu Milos OpenFOAM Installation 16 November 16, 2009 02:44
problem about installing FOAM linux freshman Main CFD Forum 6 November 4, 2004 10:59
