Compiling Error Red Hat Linux 5
Old   October 15, 2011, 15:28
Exclamation Compiling Error Red Hat Linux 5
L.Bryce Whitson Jr.
LWhitson2 is on a distinguished road
I am trying to compile OpenFOAM on RHEL 5.0 and I keep getting a lot of errors. The following is the first of the errors and I was hoping someone could help me figure out what I am doing wrong.
wmake libso mpi
'/var/local/scratch/whitsonl/programs/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so' is up to date.
+ OSspecific/POSIX/Allwmake
Found <sys/inotify.h>  --  enabling inotify for file monitoring.
'/var/local/scratch/whitsonl/programs/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libOSspecific.o' is up to date.
+ wmake libso OpenFOAM
SOURCE=meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPOpt -IlnInclude -I. -I/var/local/scratch/whitsonl/programs/OpenFOAM/OpenFOAM-2.0.x/src/OpenFOAM/lnInclude -I/var/local/scratch/whitsonl/programs/OpenFOAM/OpenFOAM-2.0.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/polyMeshTetDecomposition.o
lnInclude/globalIndexAndTransformI.H: In member function ‘Foam::labelList Foam::globalIndexAndTransform::transformIndicesForPatches(const Foam::labelHashSet&) const’:
lnInclude/globalIndexAndTransformI.H:515: warning: converting to ‘Foam::label’ from ‘double’
lnInclude/syncToolsTemplates.C: In static member function ‘static void Foam::syncTools::syncBoundaryFaceList(const Foam::polyMesh&, Foam::UList<T>&, const CombineOp&, const TransformOp&) [with T = Foam::Vector<double>, CombineOp = Foam::eqOp<Foam::Vector<double> >, TransformOp = Foam::mapDistribute::transformPosition]’:
lnInclude/syncTools.H:395:   instantiated from ‘static void Foam::syncTools::swapBoundaryFacePositions(const Foam::polyMesh&, Foam::UList<T>&) [with T = Foam::Vector<double>]’
meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C:234:   instantiated from here
lnInclude/syncToolsTemplates.C:1355: error: call of overloaded ‘Field(Foam::SubField<Foam::Vector<double> >)’ is ambiguous
lnInclude/Field.C:141: note: candidates are: Foam::Field<Type>::Field(const Foam::Field<Type>&) [with Type = Foam::Vector<double>]
lnInclude/Field.C:179: note:                 Foam::Field<Type>::Field(const Foam::UList<T>&) [with Type = Foam::Vector<double>]
lnInclude/syncToolsTemplates.C:1358: error: call of overloaded ‘Field(Foam::SubField<Foam::Vector<double> >)’ is ambiguous
lnInclude/syncToolsTemplates.C: In static member function ‘static void Foam::syncTools::syncBoundaryFaceList(const Foam::polyMesh&, Foam::UList<T>&, const CombineOp&, const TransformOp&) [with T = int, CombineOp = Foam::maxEqOp<int>, TransformOp = Foam::mapDistribute::transform]’:
lnInclude/syncTools.H:300:   instantiated from ‘static void Foam::syncTools::syncBoundaryFaceList(const Foam::polyMesh&, Foam::UList<T>&, const CombineOp&) [with T = int, CombineOp = Foam::maxEqOp<int>]’
meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C:298:   instantiated from here
lnInclude/syncToolsTemplates.C:1355: error: call of overloaded ‘Field(Foam::SubField<int>)’ is ambiguous
lnInclude/Field.C:141: note: candidates are: Foam::Field<Type>::Field(const Foam::Field<Type>&) [with Type = int]
lnInclude/Field.C:179: note:                 Foam::Field<Type>::Field(const Foam::UList<T>&) [with Type = int]
lnInclude/syncToolsTemplates.C:1358: error: call of overloaded ‘Field(Foam::SubField<int>)’ is ambiguous
make: *** [Make/linux64GccDPOpt/polyMeshTetDecomposition.o] Error 1
Thanks,
Bryce
LWhitson2 is offline   Reply With Quote
Old   October 16, 2011, 04:42
Retired Super Moderator
Bruno Santos
Greetings Bryce,
What Gcc version are you using?
gcc -v
If it's anything below 4.3.3, then you'll need to either request your system's administrator for a more recent one or build one yourself.
Another possibility is to use OpenFOAM version made available by the CentFOAM project: http://sourceforge.net/apps/mediawik...itle=Main_Page
Yet another possibility would be to use Intel's compiler, Icc, but I think you'll need at least the version 12.0 for building OpenFOAM 2.0.
Best regards and good luck!
Bruno
Dual Boot Windows and Linux and Go Open Source andyj Main CFD Forum 2 October 21, 2010 16:49
Running Fluent on Red Hat Linux WS version 4 Bob FLUENT 1 September 4, 2005 05:01
Works in Red Hat Linux 6.2 with Alpha Processer? hongchan FLUENT 1 December 24, 2001 17:32
Which version of Red Hat Linux for Fluent 5.4??? Steve Howell FLUENT 6 August 22, 2001 09:49
Fluent5 and Linux Red Hat 7.0 Anthony Wachs FLUENT 0 March 21, 2001 11:40
