December 25, 2011, 10:53 |
OpenFOAM-2.1.x on fedora 16 x86_64
Hi,I am trying to compile the sources of OpenFOAM obtained from git repo.
I am new to this fedora 16 environment,so getting lots of errors in installation. I have sources at /opt/OpenFOAM/ . I am installing as root,I followed complete steps provided by openfoam-git page,also got help from this page http://www.cfd-online.com/Forums/openfoam/94671-openfoam-2-0-x-fedora-16-64-bit.html output of foamInstallationTest is as follows:- Code:
Executing /opt/OpenFOAM/OpenFOAM-2.1.x/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: fedora.lotus OS: Linux version 3.1.6-1.fc16.x86_64 ------------------------------------------------------------------------------- Checking main OpenFOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /opt/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/anand/OpenFOAM/anand-2.1.x yes no $WM_THIRD_PARTY_DIR /opt/OpenFOAM/ThirdParty-2.1.x yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /opt/OpenFOAM/OpenFOAM-2.1.x yes yes yes $FOAM_APPBIN ...-2.1.x/platforms/linux64GccDPOpt/bin yes yes yes $FOAM_SITE_APPBIN .../2.1.x/platforms/linux64GccDPOpt/bin no no $FOAM_USER_APPBIN ...-2.1.x/platforms/linux64GccDPOpt/bin no no $WM_DIR /opt/OpenFOAM/OpenFOAM-2.1.x/wmake yes yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...-2.1.x/platforms/linux64GccDPOpt/lib yes no yes $FOAM_SITE_LIBBIN .../2.1.x/platforms/linux64GccDPOpt/lib no no $FOAM_USER_LIBBIN ...-2.1.x/platforms/linux64GccDPOpt/lib no no $MPI_ARCH_PATH ...x/platforms/linux64Gcc/openmpi-1.5.3 no yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- flex 2.5.35 /usr/bin/flex gcc 4.6.2 /usr/lib64/ccache/gcc gzip 1.4 /usr/bin/gzip tar 1.26 /bin/tar icoFoam WARNING: Conflicting installations: OpenFOAM settings : /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/icoFoam current path : CRITICAL ERROR ------------------------------------------------------------------------------- Summary ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 1 critical error(s). Review the output for warning messages and consult the installation guide for troubleshooting. Done Code:
(.text._ZN4Foam8fvMatrixIdE5relaxEd[Foam::fvMatrix<double>::relax(double)]+0x5a4): undefined reference to `Foam::reduce(double&, Foam::sumOp<double> const&, int)' Make/linux64GccDPOpt/twoPhaseEulerFoam.o: In function `Foam::fvMatrix<Foam::Vector<double> >::relax(double)': twoPhaseEulerFoam.C:(.text._ZN4Foam8fvMatrixINS_6VectorIdEEE5relaxEd[Foam::fvMatrix<Foam::Vector<double> >::relax(double)]+0x854): undefined reference to `Foam::reduce(double&, Foam::sumOp<double> const&, int)' Make/linux64GccDPOpt/twoPhaseEulerFoam.o: In function `Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate()': twoPhaseEulerFoam.C:(.text._ZN4Foam14GeometricFieldINS_10SymmTensorIdEENS_12fvPatchFieldENS_7volMeshEE22GeometricBoundaryField8evaluateEv[Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate()]+0xf1): undefined reference to `Foam::UPstream::nRequests()' twoPhaseEulerFoam.C:(.text._ZN4Foam14GeometricFieldINS_10SymmTensorIdEENS_12fvPatchFieldENS_7volMeshEE22GeometricBoundaryField8evaluateEv[Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate()]+0x24f): undefined reference to `Foam::UPstream::waitRequests(int)' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::triSurface(Foam::fileName const&)' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::triSurface()' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so: undefined reference to `Foam::UIPstream::UIPstream(Foam::UPstream::commsTypes, int, Foam::DynamicList<char, 0u, 2u, 1u>&, int&, int, bool, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber)' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::scalePoints(double)' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::triSurface(Foam::fileName const&)' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so: undefined reference to `Foam::UPstream::abort()' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::geometricSurfacePatch::operator==(Foam::geometricSurfacePatch const&) const' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::subsetMesh(Foam::List<bool> const&, Foam::List<int>&, Foam::List<int>&) const' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::edgeOwner() const' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::triSurface(Foam::List<Foam::labelledTri> const&, Foam::List<Foam::geometricSurfacePatch> const&, Foam::Field<Foam::Vector<double> > const&)' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so: undefined reference to `Foam::UPstream::init(int&, char**&)' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::geometricSurfacePatch::geometricSurfacePatch()' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::UIPstream::UIPstream(int, Foam::PstreamBuffers&)' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::triSurface::~triSurface()' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::operator=(Foam::triSurface const&)' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::sortedEdgeFaces() const' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::triSurface(Foam::List<Foam::labelledTri> const&, Foam::Field<Foam::Vector<double> > const&)' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::triSurface(Foam::triSurface const&)' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::triSurface(Foam::List<Foam::labelledTri>&, Foam::List<Foam::geometricSurfacePatch> const&, Foam::Field<Foam::Vector<double> >&, bool)' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so: undefined reference to `Foam::UPstream::addValidParOptions(Foam::HashTable<Foam::string, Foam::word, Foam::string::hash>&)' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so: undefined reference to `Foam::UPstream::exit(int)' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::faceTriangulation::faceTriangulation(Foam::Field<Foam::Vector<double> > const&, Foam::face const&, Foam::Vector<double> const&, bool)' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::~triSurface()' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::triSurface::write(Foam::fileName const&, bool) const' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `typeinfo for Foam::triSurface' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::movePoints(Foam::Field<Foam::Vector<double> > const&)' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::DimensionedField<int, Foam::triSurfaceGeoMesh>::typeName' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::triSurface(Foam::triSurface const&)' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::markZones(Foam::List<bool> const&, Foam::List<int>&) const' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::writeStats(Foam::Ostream&) const' /opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::clearOut()' collect2: ld returned 1 exit status make[2]: *** [/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/twoPhaseEulerFoam] Error 1 make[1]: *** [twoPhaseEulerFoam] Error 2 make[1]: Target `application' not remade because of errors. make: *** [multiphase] Error 2 make: Target `application' not remade because of errors. |
fedora 16, openfoam 2.1.x |
OpenFoam 1.7.1 on Fedora 12 Help... | Alphax | OpenFOAM Installation | 7 | November 2, 2012 14:33 |
OpenFOAM 2.0.x on Fedora 16 64-bit | JonW | OpenFOAM | 0 | November 22, 2011 10:31 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
OpenFOAM 1.7.1 installation problem on Fedora 14 | armonica | OpenFOAM Installation | 16 | March 31, 2011 13:16 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
