OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64
Like Tree5Likes
Old   November 7, 2011, 05:31
Default OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
Hi Foamers,
is it possible to compile 1.6-ext using git on Ubuntu 11.10? It seems that OF20x is working but I need the ext version too. Did anybody already manage to work it? Any suggestions are very welcome
Thank you,
Attila
I am doing CFD Consulting Services.
Ich biete CFD Strömungssimulationen an.
Attesz is offline   Reply With Quote
Old   November 7, 2011, 15:21
Retired Super Moderator
Bruno Santos
Greetings Attila,
I hope you don't mind, but I'm going to recycle my own words:
Originally Posted by wyldckat View Post
The fix OpenCFD/SGI made for OpenFOAM 2.0.x was this: https://github.com/OpenFOAM/OpenFOAM...3e8d0e85b889d9
If you do a similar fix on 1.6-ext, it should work as intended.
Best regards,
Bruno
Old   November 7, 2011, 15:47
Attesz's Avatar
Attesz
Hi Bruno,
thank you very much. If i understand it well, I should replace the lines marked with red to the lines marked with green in the files as written in the headers of the six boxes, and then compile?
Regards,
Attila
Old   November 7, 2011, 15:55
Bruno Santos
Hi Attila,
Yep, that's the idea: replace the red lines with the green lines
Actually, you might want to check what exactly was removed and/or added on each line, because the red lines might be different on 1.6-ext.
Keep in mind that I haven't tested this combo (Ubuntu 11.10 + 1.6-ext), but the fix made for OpenFOAM 2.0.x was that one.
Best regards,
Bruno
Old   November 7, 2011, 16:03
Attesz's Avatar
Attesz
Thanks, I'm just learning programming Otherwise, in the 1.6-ext source code, I only found the wmake/rules/linux64Gcc/c++ file, the other ones do not exist...
Is it enough to modify?
Regards
Old   November 8, 2011, 03:31
Bruno Santos
Hi Attila,
I hope you've managed to figure it out on your own, but in case you haven't, the answer to:
Is: yes.
Best regards,
Bruno
Old   November 8, 2011, 04:32
Attesz's Avatar
Attesz
Ok thanks Bruno. Now I start to compile OF20x and 1.6-et on 11.10, and I'm also writing a manual on it. If it is working, I will share it.
Regards,
Attila
Old   November 8, 2011, 14:10
Unhappy Problems
Attesz's Avatar
Attesz
I've modified the source code, but I have problems with the compilation. I copy here the last 100 lines of the log I got many messages like '/usr/bin/ld: cannot find -lmeshTools' and it's the same in case of other applications. I'm probably using newer versions of Qt and everything as when these descriptions were made:
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD/OpenFOAMonYourOwnLaptop.html
and
http://www.extend-project.de/user-fo...n-openfoam#276
Is it a problem? Anyway, using the above mentioned description I couldn't manage to compile 1.6-ext.
But at least OF2.0.x is working fine on 11.10.
So the codes, please give me advice:
collect2: ld returned 1 exit status
make[3]: *** [/home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/PSD] Error 1
make[2]: *** [PSD] Error 2
/usr/bin/ld: warning: -z nodefs ignored.
/usr/bin/ld: cannot find -ltriSurface
/usr/bin/ld: cannot find -ldynamicMesh
make[2]: *** [/home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/surfaceToPatch] Error 1
make[1]: *** [surfaceToPatch] Error 2
gcc -m64 -Xlinker -z -Xlinker nodefs Make/linux64GccDPOpt/surfaceTransformPoints.o -L/home/attila/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt \
-lmeshTools -ltriSurface -lOpenFOAM -liberty -ldl -lm -o /home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/surfaceTransformPoints
gcc -m64 -Xlinker -z -Xlinker nodefs Make/linux64GccDPOpt/stressDifferences.o -L/home/attila/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt \
-lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/stressDifferences
make[2]: *** [/home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/surfaceTransformPoints] Error 1
make[1]: *** [surfaceTransformPoints] Error 2
make[1]: Target `application' not remade because of errors.
make: *** [surface] Error 2
/usr/bin/ld: cannot find -lfiniteVolume
make[3]: *** [/home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/stressDifferences] Error 1
make[2]: *** [stressDifferences] Error 2
gcc -m64 -Xlinker -z -Xlinker nodefs Make/linux64GccDPOpt/wallGradU.o -L/home/attila/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt \
-lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/wallGradU
gcc -m64 -Xlinker -z -Xlinker nodefs Make/linux64GccDPOpt/stressSymmComponents.o -L/home/attila/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt \
-lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/stressSymmComponents
make[3]: *** [/home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/wallGradU] Error 1
make[2]: *** [wallGradU] Error 2
make[3]: *** [/home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/stressSymmComponents] Error 1
make[2]: *** [stressSymmComponents] Error 2
make[2]: Target `application' not remade because of errors.
make[1]: *** [viscoelastic] Error 2
gcc -m64 -Xlinker -z -Xlinker nodefs Make/linux64GccDPOpt/wallHeatFlux.o -L/home/attila/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt \
-lcompressibleRASModels -lreactionThermophysicalModels -lfiniteVolume -lspecie -lbasicThermophysicalModels -lOpenFOAM -liberty -ldl -lm -o /home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/wallHeatFlux
gcc -m64 -Xlinker -z -Xlinker nodefs Make/linux64GccDPOpt/IFCLookUpTableGen.o -L/home/attila/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt \
-lspecie -lmeshTools -lOpenFOAM -lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/IFCLookUpTableGen
/usr/bin/ld: cannot find -lcompressibleRASModels
/usr/bin/ld: cannot find -lreactionThermophysicalModels
/usr/bin/ld: cannot find -lbasicThermophysicalModels
make[3]: *** [/home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/wallHeatFlux] Error 1
make[2]: *** [wallHeatFlux] Error 2
make[2]: *** [/home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/IFCLookUpTableGen] Error 1
make[1]: *** [IFCLookUpTableGen] Error 2
make[2]: `/home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/adiabaticFlameT' is up to date.
gcc -m64 -Xlinker -z -Xlinker nodefs Make/linux64GccDPOpt/wallShearStress.o -L/home/attila/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt \
-lincompressibleRASModels -lincompressibleTransportModels -lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/wallShearStress
gcc -m64 -Xlinker -z -Xlinker nodefs Make/linux64GccDPOpt/chemkinToFoam.o -L/home/attila/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt \
-lreactionThermophysicalModels -lbasicThermophysicalModels -lspecie -lOpenFOAM -liberty -ldl -lm -o /home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/chemkinToFoam
/usr/bin/ld: cannot find -lincompressibleRASModels
/usr/bin/ld: cannot find -lincompressibleTransportModels
make[3]: *** [/home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/wallShearStress] Error 1
make[2]: *** [wallShearStress] Error 2
make[2]: *** [/home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/chemkinToFoam] Error 1
make[1]: *** [chemkinToFoam] Error 2
make[2]: `/home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/equilibriumCO' is up to date.
gcc -m64 -Xlinker -z -Xlinker nodefs Make/linux64GccDPOpt/yPlusLES.o -L/home/attila/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt \
-lincompressibleLESModels -lincompressibleTransportModels -lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/yPlusLES
make[2]: `/home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/equilibriumFlameT' is up to date.
/usr/bin/ld: cannot find -lincompressibleLESModels
make[3]: *** [/home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/yPlusLES] Error 1
make[2]: *** [yPlusLES] Error 2
make[2]: `/home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/mixtureAdiabaticFlameT' is up to date.
make: *** [thermophysical] Error 2
gcc -m64 -Xlinker -z -Xlinker nodefs Make/linux64GccDPOpt/yPlusRAS.o -L/home/attila/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt \
-lincompressibleTransportModels -lincompressibleRASModels -lbasicThermophysicalModels -lspecie -lcompressibleRASModels -lfiniteVolume -lmeshTools -lsampling -lOpenFOAM -liberty -ldl -lm -o /home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/yPlusRAS
/usr/bin/ld: cannot find -lsampling
Old   November 8, 2011, 15:34
Attesz's Avatar
Attesz
I get compliation errors of ParaView as well:
Linking C shared library ../../../bin/libvtkNetCDF.so
[ 5%] Built target vtkNetCDF
make: *** [all] Error 2
error: Bad exit status from /home/attila/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/tmp/rpm-tmp.VlyXCW (%build)
RPM build errors:
Installing package: ParaView-3.10.1
Uninstalling ParaView-3.10.1 using RPM: ParaView-3.10.1-linux64GccDPOpt.x86_64
Installing ParaView-3.10.1 using RPM file: /home/attila/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/x86_64/ParaView-3.10.1-linux64GccDPOpt.x86_64.rpm
error: open of /home/attila/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/x86_64/ParaView-3.10.1-linux64GccDPOpt.x86_64.rpm failed: No such file or directory
Done installing package
Old   November 8, 2011, 15:45
David Gaden
marupio is on a distinguished road
You also need to add -lrt to linker options for scotch.
File: src/decompositionMethods/scotchDecomp/Make/options:
 LIB_LIBS = \
     -L$(SCOTCH_LIB_DIR) -lscotch \
     -L$(SCOTCH_LIB_DIR) -lscotcherrexit \
     -lrt
I never got Paraview working. I think I saw a solution to that one floating around here somewhere. You need to add an include to the top of one of its source build files. Can't remember.
mm.abdollahzadeh likes this.
Follow me on twitter @DavidGaden
marupio is offline   Reply With Quote
Old   November 8, 2011, 15:54
Attesz's Avatar
Attesz
Thanks David! Isn't it a problem to have a semi-compiled paraview in the ThirdParty directory? Now I started again to compile OF. Every time I compile it, the whole code will be compiled or just the modified/new files? (beginner programmer question)
Do you have a working 1.6-ext on Ubuntu 11.10?
Regards,
Attila
Old   November 8, 2011, 16:02
David Gaden
You can compile OpenFOAM with trash in the Paraview directory - it is totally independent. As for compiling a project in OpenFOAM, only the modified libraries / applications will be compiled. wmake seems to be good at managing this. Sometimes it will mess up, and you'll know it when things should work but don't. Then I set fire to everything in my project directory:
$ rmdepall
$ rm -rf lnInclude
$ wclean all
and try again.
Old   November 8, 2011, 16:05
Attesz's Avatar
Attesz
Ok, thank you for your help!
Old   November 8, 2011, 17:12
Attesz's Avatar
Attesz
It's still running but I get the same errors as before. Have you ever managed to install 1.6-ext on 11.10?
make[2]: *** [/home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/dieselEngineFoam] Error 1
make[1]: *** [dieselEngineFoam] Error 2
Making dependency list for source file dieselFoam.C
SOURCE=dieselFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I../dieselEngineFoam -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels/compressible/turbulenceModel -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/lagrangian/basic/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/lagrangian/dieselSpray/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/liquids/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/liquidMixture/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/specie/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/thermophysicalFunctions/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/reactionThermo/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/basic/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/laminarFlameSpeed/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/../applications/solvers/reactionThermo/XiFoam -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/chemistryModel/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/ODE/lnInclude -IlnInclude -I. -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/dieselFoam.o
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/dynamicMesh/dynamicMesh/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/meshTools/lnInclude -IlnInclude -I. -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/sonicFoamAutoMotion.o -L/home/attila/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt \
-lfiniteVolume -ldynamicMesh -lmeshTools -llduSolvers -lOpenFOAM -liberty -ldl -lm -o /home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/sonicFoamAutoMotion
make[2]: *** [/home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/sonicFoamAutoMotion] Error 1
make[1]: *** [sonicFoamAutoMotion] Error 2
Old   November 8, 2011, 17:18
David Gaden
In the errors you listed above, none of the linker commands include the extra options that should be there: -shared -Xlinker --add-needed -Xlinker --no-as-needed
That means you didn't apply the changes (that Bruno suggested above) correctly. You need to edit your wmake/rules files.
Old   November 8, 2011, 17:26
Attesz's Avatar
Attesz
I forget to modify one c++ file, but the from the 6 listed file there is only 2 in 1.6-ext, and I still get the same errors. Should I modify all the c++ files in the rules dictionary?
Old   November 9, 2011, 04:49
Attesz's Avatar
Attesz
I modified two C++ files, added the lines what you suggested and modified other stuff described here:
But I still get the same errors. Otherwise I tried to install 1.6-ext on a fresh Natty system and it didn't work as well despite I followed this description accurately...
I copy lines from the most recent compilation:
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/triSurface/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/meshTools/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/dynamicMesh/dynamicMesh/lnInclude -IlnInclude -I. -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/cellSplitter.o Make/linux64GccDPOpt/modifyMesh.o -L/home/attila/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt \
-ltriSurface -lmeshTools -ldynamicMesh -lOpenFOAM -liberty -ldl -lm -o /home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/modifyMesh
make[3]: *** [/home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/modifyMesh] Error 1
make[2]: *** [modifyMesh] Error 2
Making dependency list for source file refineHexMesh.C
SOURCE=refineHexMesh.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/dynamicMesh/dynamicMesh/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/meshTools/lnInclude -IlnInclude -I. -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/refineHexMesh.o
^[OFg++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/errorEstimation/lnInclude -IlnInclude -I. -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/icoErrorEstimate.o -L/home/attila/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt \
-lerrorEstimation -lmeshTools -ldynamicMesh -lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/icoErrorEstimate
/usr/bin/ld: cannot find -lerrorEstimation
make[2]: *** [/home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/icoErrorEstimate] Error 1
make[1]: *** [icoErrorEstimate] Error 2
Making dependency list for source file icoMomentError.C
SOURCE=icoMomentError.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/errorEstimation/lnInclude -IlnInclude -I. -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/attila/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/icoMomentError.o
Should I start over from scratch again?
Old   November 9, 2011, 06:06
Attesz's Avatar
Attesz
I also quote the foamInstallationTest app. output:
Checking basic setup...
Shell: bash
Host: ubuntu
OS: Linux version 3.0.0-12-generic
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/attila/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/attila/OpenFOAM/attila-1.6-ext no no
$WM_THIRD_PARTY_DIR ...OpenFOAM/OpenFOAM-1.6-ext/ThirdParty yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/attila/OpenFOAM/OpenFOAM-1.6-ext yes yes yes
$FOAM_APPBIN ...ext/applications/bin/linux64GccDPOpt yes yes yes
$FOAM_SITE_APPBIN ...OAM/site/1.6-ext/bin/linux64GccDPOpt no no
$FOAM_USER_APPBIN ...ext/applications/bin/linux64GccDPOpt no no
$WM_DIR ...tila/OpenFOAM/OpenFOAM-1.6-ext/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...OpenFOAM-1.6-ext/lib/linux64GccDPOpt yes yes yes
$FOAM_SITE_LIBBIN ...OAM/site/1.6-ext/lib/linux64GccDPOpt no no
$FOAM_USER_LIBBIN ...M/attila-1.6-ext/lib/linux64GccDPOpt no no
$MPI_ARCH_PATH ...nmpi-1.4.3/platforms/linux64GccDPOpt yes yes yes
Third party software
Software Version Location
WARNING: gcc version does not match gcc supplied with this release of OpenFOAM
Supplied version: 4.3.3
User version : 4.6.1
Minimum required: 4.3.1
gcc 4.6.1 /usr/bin/gcc
gzip 1.3.12 /bin/gzip
tar 1.25 /bin/tar
icoFoam
WARNING: Conflicting installations:
OpenFOAM settings : /home/attila/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/icoFoam
current path :
CRITICAL ERROR
Summary
Base configuration ok.
The foam installation contains 1 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
done.
I'm using newer gcc, isn't it a problem maybe?
Thank you in advance!
Attila
Old   November 9, 2011, 10:17
David Gaden
Yeah, I'd start all over. Next time you run Allwmake use this command:
./Allwmake 2>&1 | tee output
Then when it completes, open output and do a case-sensitive search for "Error". The first Error 1 or Error 2 or Error 3 you encounter, this is your problem. Copy this line, along with about 5 lines up and 5 lines down for context. Or just attach output as a file attachment to this thread. Report back.
Also, did you make the changes to src/decompositionMethods/scotchDecomp/Make/options that I mentioned above?
Last edited by marupio; November 9, 2011 at 10:17. Reason: Opps, said "attach error", meant "attach output"
Old   November 9, 2011, 10:22
Attesz's Avatar
Attesz
Yes I did the log and I attach it. I made the changes in the options file.
Otherwise, I only need the GGI part of 1.6ext, but I think it's more difficult to recompile 2.0.x the GGI part...
Thank you!
log_Allwmake_1.zip
11.10, ext, of extended
OpenFOAM 1.7.1 installation problem on Fedora 14 armonica OpenFOAM Installation 16 March 31, 2011 13:16
Error in apt-get update for installation of OpenFoam 1.7.1 on Ubuntu 10.10 StuntedChicken OpenFOAM Installation 1 January 9, 2011 10:43
New openfoam installation fivos OpenFOAM Installation 5 April 1, 2009 03:58
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
