[blockMesh] circle define
Like Tree1Likes
  • 1 Post By haakon
Old   May 17, 2013, 01:07
Default circle define
immortality's Avatar
Ehsan
immortality is on a distinguished road
whats the command for defining a semi-circle(a piece of arc!) by blockMesh?
I want to model a circular tank that is attached to a pipe,how to do it?(maybe defining a full circle and add it with a rectangle,how?)
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   May 18, 2013, 05:03
haakon will become famous soon enough
Have you seen the cylinder tutorial for potentialFoam? It contains a mesh around half a cylinder, and it should be fairly easy to extend it both for a complete cylinder and a full 3D case. It does describe how to create an arc fairly well.
See the tutorial folder: tutorials/basic/potentialFoam/cylinder
Also see the the "OpenFOAM programmers Guide" page P-41. This guide is located at: doc/Guides-a4/ProgrammersGuide.pdf
But for your case (internal flow in pipe) it is of course slightly different, but it is not necessarily more difficult. See the following links for reference/inspiration:
http://image.bayimg.com/dapdiaabn.jpg
http://openfoamwiki.net/index.php/Si...rupt_Expansion
Good luck.
immortality likes this.
haakon is offline   Reply With Quote
Old   May 18, 2013, 08:04
Ehsan
thank you Hakon
the first link is baned here.could you please send it by attaching?
thanks.
Old   May 18, 2013, 09:48
See attached img.
HELP----Surface Reaction UDF Ashi Fluent UDF and Scheme Programming 1 May 19, 2020 21:13
SR_Rate UDF For a MEMs model timjm Fluent UDF and Scheme Programming 1 October 10, 2018 02:16
Define new turbulence model in Fluent micro11sl Fluent UDF and Scheme Programming 55 October 27, 2016 17:25
udf problem eb.nabizadeh Fluent UDF and Scheme Programming 2 March 1, 2013 00:28
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 129 June 19, 2010 09:23
