May 17, 2013, 01:07 |
circle define
Ehsan
Rep Power: 26 |
whats the command for defining a semi-circle(a piece of arc!) by blockMesh?
I want to model a circular tank that is attached to a pipe,how to do it?(maybe defining a full circle and add it with a rectangle,how?)
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
May 18, 2013, 05:03 |
Rep Power: 19 |
Have you seen the cylinder tutorial for potentialFoam? It contains a mesh around half a cylinder, and it should be fairly easy to extend it both for a complete cylinder and a full 3D case. It does describe how to create an arc fairly well.
See the tutorial folder: tutorials/basic/potentialFoam/cylinder Also see the the "OpenFOAM programmers Guide" page P-41. This guide is located at: doc/Guides-a4/ProgrammersGuide.pdf But for your case (internal flow in pipe) it is of course slightly different, but it is not necessarily more difficult. See the following links for reference/inspiration: http://image.bayimg.com/dapdiaabn.jpg http://openfoamwiki.net/index.php/Si...rupt_Expansion Good luck. |
May 18, 2013, 08:04 |
Ehsan
Rep Power: 26 |
thank you Hakon
the first link is baned here.could you please send it by attaching? thanks.
May 18, 2013, 09:48 |
Rep Power: 19 |
See attached img.
HELP----Surface Reaction UDF | Ashi | Fluent UDF and Scheme Programming | 1 | May 19, 2020 21:13 |
SR_Rate UDF For a MEMs model | timjm | Fluent UDF and Scheme Programming | 1 | October 10, 2018 02:16 |
Define new turbulence model in Fluent | micro11sl | Fluent UDF and Scheme Programming | 55 | October 27, 2016 17:25 |
udf problem | eb.nabizadeh | Fluent UDF and Scheme Programming | 2 | March 1, 2013 00:28 |
Installing OF 1.6 on Mac OS X | gschaider | OpenFOAM Installation | 129 | June 19, 2010 09:23 |
