[blockMesh] How to get this mesh with one hex in blockMeshDict
Like Tree1Likes
  • 1 Post By cutter
Old   August 30, 2013, 01:10
Post How to get this mesh with one hex in blockMeshDict
xuhe-openfoam
bieshuxuhe is on a distinguished road
Hi , I am a beginner in OpenFOAM.
I want to get the mesh in the following picture with only one hex(or other cellModel) in blockMesh.
Could you help me? The mesh is in the "picture(mesh).jpg".
Thank you!
bieshuxuhe is offline   Reply With Quote
Old   August 30, 2013, 03:19
cutter is on a distinguished road
the picture shows six cells - could you explain a little further?
Basically you can start with a single block (see tutorial) and fix the positions of the corner points. You need to define two pairs of coincident vertices (same coordinates) so your single hex block becomes degenerated into a prism.
Afterwards you may want to adapt the discretization of the block as desired.
cutter
cutter is offline   Reply With Quote
Old   August 30, 2013, 03:52
Post furter explain
xuhe-openfoam
Originally Posted by cutter View Post
cutter
Thank you for your reply!
It is a 2D mesh,so there is a layer of cell in the z direction.
I know how to get a hex to become a prism, as user guide has told us. But I could only get a prism mesh that I don't desire to get. The mesh not desired is in the "picture(not desired).jpg".
How could I get a mesh which is described in the "picture(mesh).jpg"?
Old   August 30, 2013, 05:20
This is not possible with a single hex block because blockMesh discretizes the hex blocks along topological parallel edges.
immortality likes this.
blockmesh
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[blockMesh] how to create a dense mesh in blockMeshdict? Shanmukhi OpenFOAM Meshing & Mesh Conversion 1 August 3, 2015 14:23
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[Other] 2D hex mesh on multi element airfoil Verfblikje OpenFOAM Meshing & Mesh Conversion 0 January 19, 2012 10:55
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
