[blockMesh] strange errror, when using OF2.2.2 and switching to OF1.6ext checking the mesh
Old   March 22, 2014, 06:15
Default strange errror, when using OF2.2.2 and switching to OF1.6ext checking the mesh
knoedl1 is on a distinguished road
Hi everybody!
I had a working blockMeshDict file running on OF 2.2.2, but now i have to work it out on OF1.6ext. I know that the syntax is a little bit different, like instead of boundary( );
you have to write patches ( );
But everytime i write checkMesh in the terminal, the following error is coming up:
 Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    all points:           12
    live points:           12
    all faces:            14
    live faces:            14
    internal faces:   2
    cells:            3
    boundary patches: 9
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     1
    prisms:        2
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
    Patch               Faces    Points   Surface topology
    front               3        8        ok (non-closed singly connected)
    back                3        8        ok (non-closed singly connected)
    Netzoberflaeche_1   1        3        ok (non-closed singly connected)
    Netzoberflaeche_2   1        4        ok (non-closed singly connected)
    Netzoberflaeche_3   1        3        ok (non-closed singly connected)
    Gasturbine          1        4        ok (non-closed singly connected)
    Einlass_Gasturbinenauslass1        3        ok (non-closed singly connected)
    Auslass_Gasturbineneinlass1        3        ok (non-closed singly connected)
    defaultFaces        0        0        ok (empty)
Checking geometry...
    This is a 3-D mesh
    Overall domain bounding box (0 -0.3 -0.0115774) (0.265165 0.45 0.0115774)
    Mesh (non-empty, non-wedge) directions (1 1 0)
    Mesh (non-empty, non-wedge) dimensions 2
 ***Number of edges not aligned with or perpendicular to non-empty directions: 12
  Writing 12 points on non-aligned edges to set nonAlignedEdges
    Boundary openness (3.1462e-19 0 4.02714e-17) Threshold = 1e-06 OK.
    Max cell openness = 1.4789e-16 OK.
    Max aspect ratio = 24.7206 OK.
    Minumum face area = 0.000109152. Maximum face area = 0.0732614.  Face area magnitudes OK.
    Min volume = 0.000350603. Max volume = 0.00113527.  Total volume = 0.00183648.  Cell volumes OK.
    Mesh non-orthogonality Max: 26.2222 average: 26.2222 Threshold = 70
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 1.56028 OK.
Failed 1 mesh checks.
End
I dont know, i changed the direction of the patches, i copyed the vertices and everything in a running tutoriol of OF1.6ext, that was also not working.
I have to say i that in my case i have an axisymetric wedge with one cell in z direction and in my case 2 patches are empty!
Maybe its just a simple syntax problem but i tried everything out. Perhabs there is somebod how was having the same problem ???
knoedl1 is offline   Reply With Quote
Old   March 22, 2014, 06:30
here is i would say is the same error described
http://www.cfd-online.com/Forums/ope...irections.html
Old   March 22, 2014, 06:38
thats the blockMeshDict file:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.001;
vertices
   ( 0          -300                 0          )//0
   ( 0           0                   0          )//1
   ( 0           150                 0          )//2
   ( 0           450                 0          )//3
   ( 265.165043 -190.1650429       -11.5773558  )//4
   ( 50          0                 -2.18304715  )//5
   ( 50          150               -2.18304715  )//6
   ( 265.165043  340.1650429       -11.5773558  )//7
   ( 265.165043 -190.1650429        11.5773558  )//8
   ( 50          0                   2.18304715 )//9
   ( 50          150                 2.18304715 )//10
   ( 265.165043  340.1650429        11.5773558  )//11
blocks
  hex (0 4 5 1 0 8  9  1)  (1 1 1)   simpleGrading (1   1  1)  //Block1
  hex (5 4 7 6 9 8 11 10)  (1 1 1)   simpleGrading (1   1  1)  //Block2
  hex (2 6 7 3 2 10 11 3)  (1 1 1)   simpleGrading (1   1  1)  //Block3
edges
  arc 0 4  (143.506287 -271.454827 -6.26561981)  //H11
  arc 0 8  (143.506287 -271.454827  6.26561981)  //H12
  arc 4  7 (375 75 -16.3728536)     //H21
  arc 8 11 (375 75  16.3728536)    //H22
  arc 3 7  (143.506287 421.4548247 -6.26561981)  //H31
  arc 3 11 (143.506287 421.4548247  6.26561981)   //H32
patches
    wedge front
           (0 1 5 4)   //zu Block1
       (4 5 6 7)   //zu Block2
       (2 3 7 6)   //zu Block3
    wedge back
      (0 8 9 1)           //zu Block1
      (9 8 11 10)        //zu Block2
      (2 10 11 3)       //zu Block3
    empty unten
      (1 0 0 1)
      (3 2 2 3)
    patch oberflaeche_1
       ( 4 8 0 4)   //Block1
   patch oberflaeche_2
         (4 8 11 7)  //Block2
    patch oberflaeche_3
        (3 11 7 3)  //Block3
    wall Gasturbine
      (5 9 10 6) //Block2
   patch Einlass
     (2 6 10 2)  // Block3
    patch Auslass
         (1 5 9 1) //Block1
mergePatchPairs
Old   March 22, 2014, 07:11
Retired Super Moderator
Bruno Santos
Greetings knoedl1 and welcome to the forum!
Are you sure that the mesh was working correctly in OpenFOAM 2.2.2?
I ask this because a quit inspection to the "blockMeshDict" shows me that this:
    empty unten
      (1 0 0 1)
      (3 2 2 3)
is probably very wrong. In addition, that patch does not appear in the checkMesh output.
Regarding the changes between 2.2.2 and 1.6-ext, here is the command I've used:
diff -Nur OpenFOAM-2.2.2/tutorials/incompressible/icoFoam/cavity/constant/polyMesh/blockMeshDict OpenFOAM-1.6-ext/tutorials/incompressible/icoFoam/cavity/constant/polyMesh/blockMeshDict
to get this:
--- OpenFOAM-2.2.2/tutorials/incompressible/icoFoam/cavity/constant/polyMesh/blockMeshDict    2013-10-17 20:40:53.361975774 +0100
+++ OpenFOAM-1.6-ext/tutorials/incompressible/icoFoam/cavity/constant/polyMesh/blockMeshDict    2013-12-25 13:10:06.947440667 +0000
@@ -1,8 +1,8 @@
-| \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |
-|  \\    /   O peration     | Version:  2.2.2                                 |
-|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
+| \\      /  F ield         | OpenFOAM Extend Project: Open Source CFD        |
+|  \\    /   O peration     | Version:  1.6-ext                               |
+|   \\  /    A nd           | Web:      www.extend-project.de                 |
 FoamFile
@@ -37,35 +37,23 @@
-boundary
+patches
-    movingWall
-        type wall;
-        faces
-            (3 7 6 2)
-    fixedWalls
-        type wall;
-        faces
-            (0 4 7 3)
-            (2 6 5 1)
-            (1 5 4 0)
-    frontAndBack
-        type empty;
-        faces
-            (0 3 2 1)
-            (4 5 6 7)
+    wall movingWall
+        (3 7 6 2)
+    wall fixedWalls
+        (0 4 7 3)
+        (2 6 5 1)
+        (1 5 4 0)
+    empty frontAndBack
+        (0 3 2 1)
+        (4 5 6 7)
 mergePatchPairs
Best regards,
Bruno
Old   March 22, 2014, 07:42
Hi Bruno thank you very much for your quick answer!
IN OF2.2.2 i had no empty patch inside, i delete it there,
but i thought maybe in OF1.6ext he also wants to have the empty patch?
Old   March 22, 2014, 07:45
ok this is the new error message, here in this case i put the "empty unten" into the
patches( );
Create time
Time = 0
Mesh stats
all points: 12
live points: 12
all faces: 14
live faces: 14
internal faces: 2
cells: 3
boundary patches: 9
point zones: 0
face zones: 0
cell zones: 1
hexahedra: 1
prisms: 2
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Point usage OK.
Face vertices OK.
unten 0 0 ok (empty)
Einlass 1 3 ok (non-closed singly connected)
Auslass 1 3 ok (non-closed singly connected)
This is a 3-D mesh
Face pyramids OK.
End
Old   March 22, 2014, 09:27
Bruno Santos
I think you can safely ignore that message, since there is no clear indication on whether there is anything wrong with it.
And please use the "[CODE]" markers when posting code, output and file contents here on the forum, as explained in one of my signature links: Posting code and output with [CODE]
