[blockMesh] Geometry by blockMesh
Old   October 27, 2014, 01:17
Default Geometry by blockMesh
Mominul MuKuT
mukut is on a distinguished road
Experimentally I have investigated the effect of a special type of VG on flow separation in a diffuser of a wind tunnel. Wind tunnel geometry is as like attached image:
Using blockMesh, I have made the flow domain of wind tunnel including the diffuser section which is as below:
But I don't understand how can I make the VG geometry over the bottom plate of wind tunnel upstream of diffuser [see first image]. Is it possible to make VG geometry by blockMesh? or any other software necessary in this regard?
Thanks in advance.
mukut is offline   Reply With Quote
Old   October 28, 2014, 04:00
Mominul MuKuT
Hello! Any suggestion? I am waiting for your kind suggestion/advice regarding this.....
Old   October 28, 2014, 05:12
Elvis
elvis will become famous soon enough
I do not understand your problem, maybe one of the GUI will support you with more complex Blockmesh geometries, have a look at SwiftBlock http://openfoamwiki.net/index.php/Contrib/SwiftBlock
http://www.cfd-online.com/Forums/ope...s-meshers.html
elvis is offline   Reply With Quote
Old   October 28, 2014, 05:27
Mominul MuKuT
Dear elvis,
Thanks for reply. Using blockMesh, I have made the domain as shown below:
Now I would like to introduce VG inside this flow domain like as shown below:
How can I do this?
Thanks
Old   October 29, 2014, 05:38
Julian Langowski
Ruli is on a distinguished road
Hi Mominul,
if the VGs have a very "straight-forward" geometry, you could use blockMesh. You just have to figure out a way, how to lay the blocks around the VGs.
Anyhow, using snappyHexMesh might be a lot easier.
Best regards
Julian
πάντα ῥεῖ - Heraclitus
Ruli is offline   Reply With Quote
Old   October 29, 2014, 05:48
Mominul MuKuT
Dear Ruli,
Actually the VG is a rectangular vane VG which is placed 25 deg with flow direction. So, it is possible to make such vg having 25 deg angle with x direction by blockMesh?
And before using snappyHexMesh, may be it is necessary to make stl of such VG, right?
Thanks
Old   October 29, 2014, 05:59
Julian Langowski
Dear Mukut,
Hmm, hard to say without image of the VG. I guess, the shape is quite simple, so you could give it a try with blockMesh.
You have to keep in mind: in blockMesh you have to manually define all the blocks, which your mesh consists off (as you did with the basic wind tunnel shape).
Thus, if the VGs have a simple rectangular shape, it might be possible with blockMesh, although it is tideous work...
That is true!
Best regards
Julian
Old   October 29, 2014, 06:22
Mominul MuKuT
Here is the closer look of 3 VG arrangement upstream of diffuser.
VG length is 28mm, height 7mm, thickness 1mm
Old   October 29, 2014, 06:45
Mominul MuKuT
Dear Ruli,
Would you please share your idea about how to make VG with blockmesh? This VG is not parallel with x direction. I am waiting to know your idea.
Thanks again
wind tunnel
[blockMesh] blockmesh arc, no curves, no arc, only straight lines heavy_user OpenFOAM Meshing & Mesh Conversion 9 January 26, 2017 20:48
Import Deformed Geometry into Fluent lgamble FLUENT 1 February 25, 2016 13:59
[blockMesh] Trouble using blockMesh for axisymmetric geometry twinturbotom OpenFOAM Meshing & Mesh Conversion 1 February 8, 2016 20:59
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
Help to create geometry using blockMesh nandiganavishal OpenFOAM Running, Solving & CFD 11 January 13, 2009 14:20
