October 27, 2014, 01:17 |
Geometry by blockMesh
Mominul MuKuT
Experimentally I have investigated the effect of a special type of VG on flow separation in a diffuser of a wind tunnel. Wind tunnel geometry is as like attached image:
Using blockMesh, I have made the flow domain of wind tunnel including the diffuser section which is as below: But I don't understand how can I make the VG geometry over the bottom plate of wind tunnel upstream of diffuser [see first image]. Is it possible to make VG geometry by blockMesh? or any other software necessary in this regard? Thanks in advance. |
October 28, 2014, 04:00 |
Mominul MuKuT
Hello! Any suggestion? I am waiting for your kind suggestion/advice regarding this.....
October 28, 2014, 05:12 |
I do not understand your problem, maybe one of the GUI will support you with more complex Blockmesh geometries, have a look at SwiftBlock http://openfoamwiki.net/index.php/Contrib/SwiftBlock http://www.cfd-online.com/Forums/ope...s-meshers.html |
October 28, 2014, 05:27 |
Mominul MuKuT
Dear elvis,
Thanks for reply. Using blockMesh, I have made the domain as shown below: Now I would like to introduce VG inside this flow domain like as shown below: How can I do this? Thanks |
October 29, 2014, 05:38 |
Julian Langowski
Hi Mominul,
if the VGs have a very "straight-forward" geometry, you could use blockMesh. You just have to figure out a way, how to lay the blocks around the VGs. Anyhow, using snappyHexMesh might be a lot easier. Best regards Julian
πάντα ῥεῖ - Heraclitus |
October 29, 2014, 05:48 |
Mominul MuKuT
Dear Ruli,
Actually the VG is a rectangular vane VG which is placed 25 deg with flow direction. So, it is possible to make such vg having 25 deg angle with x direction by blockMesh? And before using snappyHexMesh, may be it is necessary to make stl of such VG, right? Thanks |
October 29, 2014, 05:59 |
#7 | ||
Julian Langowski
Dear Mukut,
You have to keep in mind: in blockMesh you have to manually define all the blocks, which your mesh consists off (as you did with the basic wind tunnel shape). Thus, if the VGs have a simple rectangular shape, it might be possible with blockMesh, although it is tideous work... Quote:
Best regards Julian
October 29, 2014, 06:22 |
Mominul MuKuT
Here is the closer look of 3 VG arrangement upstream of diffuser.
VG length is 28mm, height 7mm, thickness 1mm |
October 29, 2014, 06:45 |
Mominul MuKuT
Dear Ruli,
Would you please share your idea about how to make VG with blockmesh? This VG is not parallel with x direction. I am waiting to know your idea. Thanks again |
wind tunnel |
[blockMesh] blockmesh arc, no curves, no arc, only straight lines | heavy_user | OpenFOAM Meshing & Mesh Conversion | 9 | January 26, 2017 20:48 |
Import Deformed Geometry into Fluent | lgamble | FLUENT | 1 | February 25, 2016 13:59 |
[blockMesh] Trouble using blockMesh for axisymmetric geometry | twinturbotom | OpenFOAM Meshing & Mesh Conversion | 1 | February 8, 2016 20:59 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
Help to create geometry using blockMesh | nandiganavishal | OpenFOAM Running, Solving & CFD | 11 | January 13, 2009 14:20 |
