[mesh manipulation] How to convert tetrahedral to polyhedral
Like Tree2Likes
  • 2 Post By Micha69822
Old   November 25, 2014, 14:33
Default How to convert tetrahedral to polyhedral
wang2012 is on a distinguished road
i want to convert my mesh from tetrahedral to polyhedral for the chtMultiRegionFoam.
The mesh was built from ANSYS. I try the polyDualMesh.
polyDualMesh 180 -concaveMultiCells
combinePatchFaces 180
But they worked not so well. After convert with polyDualMesh,
the number of elements are 4 times larger than previously, and there are 99% of hexahedra and only 1% of polyhedral.
Before:
After:
I really appreciate if you help me at this.
Best,
Wang
wang2012 is offline   Reply With Quote
Old   December 3, 2014, 04:00
Dongyue Li
sharonyue is on a distinguished road
Hi bro,
There are just some extra lines brought up by paraview. U can show the perfect ploy mesh by just showing the patch, not the internalMesh.
sharonyue is offline   Reply With Quote
Old   December 15, 2014, 08:53
Michael Leck
Micha69822 is on a distinguished road
Hy,
there is an option in paraFoam to show the polyedral mesh correctly.
It's caled "Use VTKPolyhedron". It's above the mesh parts.
sharonyue and randolph like this.
Best regards
Michael
Last edited by Micha69822; December 15, 2014 at 09:00. Reason: Add the second sentence.
Micha69822 is offline   Reply With Quote
[mesh manipulation] polyDualMesh, create a tetrahedral mesh from a polyhedral mesh Martin80 OpenFOAM Meshing & Mesh Conversion 5 January 30, 2013 22:07
Tetrahedral vs Polyhedral Rohini FLUENT 3 October 5, 2011 09:20
[Technical] is possible to do tetrahedral or polyhedral mesh OpenFoam?? Ale_galleria OpenFOAM Meshing & Mesh Conversion 2 January 11, 2011 06:06
[snappyHexMesh] is possible to do tetrahedral or polyhedral mesh using snappyHexMesh?? Ale_galleria OpenFOAM Meshing & Mesh Conversion 1 September 15, 2010 12:00
How to convert cells to polyhedral Sri FLUENT 1 September 12, 2007 07:43
