February 8, 2016, 07:46 |
Inconsistent number of faces
Nikola
Rep Power: 12 |
Hi everyone.
I don't really understand where in my mesh there is no consistency. I get this error message when I try to run blockMesh for this mesh region: Inconsistent number of faces between block pair 4 and 6. Here is my blockMeshDict file: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.001; vertices ( (0 0 0) (24.35 0 0) (26 0 0) (28.50 0 0) (0 250 0) (24.35 250 0) (26 250 0) (28.50 250 0) (0 10250 0) (24.35 10250 0) (26 10250 0) (28.50 10250 0) (24.35 10471.50 0) (26 10471.50 0) (28.50 10471.50 0) (0 10495.20 0) (0 10496.85 0) (0 10498.35 0) (0 0 0.3) (24.35 0 0.3) (26 0 0.3) (28.50 0 0.3) (0 250 0.3) (24.35 250 0.3) (26 250 0.3) (28.50 250 0.3) (0 10250 0.3) (24.35 10250 0.3) (26 10250 0.3) (28.50 10250 0.3) (24.35 10471.50 0.3) (26 10471.50 0.3) (28.50 10471.50 0.3) (0 10495.20 0.3) (0 10496.85 0.3) (0 10498.35 0.3) ); blocks ( hex (0 1 5 4 18 19 23 22) (24 250 1) simpleGrading (1 1 1) hex (2 3 7 6 20 21 25 24) (2 250 1) simpleGrading (1 1 1) hex (4 5 9 8 22 23 27 26) (24 100 1) simpleGrading (1 1 1) hex (6 7 11 10 24 25 29 28) (2 100 1) simpleGrading (1 1 1) hex (8 9 12 15 26 27 30 33) (24 245 1) simpleGrading (1 1 1) hex (10 11 14 13 28 29 32 31) (2 221 1) simpleGrading (1 1 1) hex (12 13 16 15 30 31 34 33) (2 26 1) simpleGrading (1 1 1) hex (13 14 17 16 31 32 35 34) (2 28 1) simpleGrading (1 1 1) ); edges ( arc 15 12 (17.21805012 10488.71805 0) arc 33 30 (17.21805012 10488.71805 0.3) arc 16 13 (18.38477631 10489.88478 0) arc 34 31 (18.38477631 10489.88478 0.3) arc 17 14 (20.152543226 10491.65254326 0) arc 35 32 (20.152543226 10491.65254326 0.3) ); boundary ( inlet { type patch; faces ( (0 1 19 18) ); } outlet { type patch; faces ( (2 3 21 20) ); } walls { type wall; faces ( (1 5 23 19) (5 9 27 23) (9 12 30 27) (12 13 31 30) (13 10 28 31) (10 6 24 28) (6 2 20 24) (3 7 25 21) (7 11 29 25) (11 14 32 29) (14 17 35 32) ); } left { type symmetryPlane; faces ( (4 0 18 22) (8 4 22 26) (15 8 26 33) (16 15 33 34) (17 16 34 35) ); } frontAndBack { type empty; faces ( (0 4 5 1) (2 6 7 3) (4 8 9 5) (6 10 11 7) (8 15 12 9) (10 13 14 11) (12 15 16 13) (13 16 17 14) (18 22 23 19) (20 24 25 21) (22 26 27 23) (24 28 29 25) (26 33 30 27) (28 31 32 29) (30 33 34 31) (31 34 35 32) ); } ); mergePatchPairs ( ); // ************************************************************************* // |
February 18, 2016, 01:53 |
Rep Power: 15 |
Basically on the line connecting vertices 30 and 33 in block 4 you have 24 cells, while on block 6 you have 26 cells. Hence you have the error message. Cheers, Antimony P.S. You will have a similar issue with blocks 6 and 7 that you would need to correct for as well |
February 18, 2016, 06:58 |
Nikola
Rep Power: 12 |
Thanks!
That actually solved the problem |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 09:23 |
parallel run OpenFoam | Srinath Reddy | OpenFOAM Running, Solving & CFD | 13 | February 27, 2019 09:15 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 08:14 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
