November 4, 2008, 05:50 |
Grid softwares for VOF simulations
stephane sanchi
Rep Power: 18 |
Dear OF-users,
I am trying to compute VOF simulations around ships using the rasInterFoam solver. I have used the main settings of E. Patterson (wigley hull) with another geometry. But the case is crashing after a few iterations, maybe due to the quality of the mesh. I use ICEMCFD Hexa for grid generation. I was wondering what other grid softwares are used by the other users of OF (for complex geometries like cars, aircrafts and ships) ? All comments about grid softwares and how to set-up VOF simulations around ships are welcome. Regards, Stephane. |
November 4, 2008, 07:40 |
The general purpose meshing to
Eugene de Villiers
Rep Power: 21 |
The general purpose meshing tool shipped with OPENFOAM 1.5 is snappyHexMesh.
November 4, 2008, 10:12 |
Hi Eugene,
do you know a tu
stephane sanchi
Rep Power: 18 |
Hi Eugene,
do you know a tutorial for snappyHexMesh with complex geometry ? Stephane |
November 5, 2008, 07:07 |
Hello Stephane,
I'm working
Anders Östman
Rep Power: 17 |
Hello Stephane,
I'm working on the same type of computations. I also experienced that the solver crashed with the wigley tutorial settings on a realistic hull. I had to change the scheme to more upwind weighting. I got convergence with the following settings. divSchemes { div(rho*phi,U) Gauss upwind; div(phi,gamma) Gauss upwind; div(phirb,gamma) Gauss interfaceCompression; div(phi,k) Gauss upwind; div(phi,epsilon) Gauss upwind; div(phi,R) Gauss upwind; div(R) Gauss linear; div(phi,nuTilda) Gauss upwind; div((nuEff*dev(grad(U).T()))) Gauss linear; } laplacianSchemes { default Gauss linear corrected limited 0.5; } I have not yet compared the computed drag with my own CFD solver, so I don't know if it gives to mush diffusion to the solution. Anders |
November 5, 2008, 07:35 |
Hi Anders,
Thanks. I will t
stephane sanchi
Rep Power: 18 |
Hi Anders,
Thanks. I will try your settings and give you a feedback asap. Which software do you use for mesh generation ? Have you tried snappyHexMesh ? Stephane. |
November 5, 2008, 08:40 |
Stephane,
I use an in-house
Anders Östman
Rep Power: 17 |
Stephane,
I use an in-house gridgenerator where I have developed an efficient parametric template for ship hulls. However I have not yet succeeded in converting meshes from our format to the OpenFOAM grid format (work in progress...). The only ship hull I have yet computed in OpenFOAM was generated by the StarCCM+ software. I have not yet had time to look in to the snappyHexMesh utility. Anders |
November 5, 2008, 13:25 |
Hi Stephane,
On our side we
Vincent RIVOLA
Rep Power: 18 |
Hi Stephane,
On our side we use GridPro to create meshes around ships and planes. We created a converter from GridPro to OpenFOAM which is available on the forum and works for a large band of cases (still needs some code implementation for periodic boundary conditions). I did not make computations on ships but some clients did. If you want some other information, do not hesitate to contact me. Hope that helped. Regards |
November 6, 2008, 02:35 |
Dear Anders, dear Vincent,
stephane sanchi
Rep Power: 18 |
GridPro are among the best grid softwares with ICEM and Gridgen. I am a new user of OpenFOAM. And maybe beginning with free surface computations is not the simplest thing. I have done meshes around ship with ICEM hexa. The quality seems good, but the computation crashes after some iterations. I have download the mesh of E. Patterson (wigley hull) and his settings. The case runs well. Just changing the geometry make the case crashes after less than 10 iterations. Stephane. |
November 6, 2008, 03:17 |
Hi Stephane,
I don't know i
#9 |
Vincent RIVOLA
Rep Power: 18 |
Hi Stephane,
I don't know if your geometry is very confidential. But if it's not, i can give it a look and try to do a mesh so you can try a different mesh generator and see if it's coming from that or not. If you want, just send me an email, so we can arrange everything. Vincent |
[Other] Some questions about unstructured grid. | Yanci | OpenFOAM Meshing & Mesh Conversion | 1 | November 28, 2014 10:47 |
Problem with grid sensitive test cases(shock instability) in SU2.!!! | Vino | SU2 | 2 | November 27, 2014 04:33 |
grid on a circle | HaKu | Main CFD Forum | 4 | April 15, 2010 11:56 |
MapFields to New Grid For Extreme Grid Deformations due to Body Motion | albcem | OpenFOAM | 0 | May 5, 2009 14:17 |
GRID TO GRID INTERPOLATION in FLUENT | calogero | FLUENT | 3 | June 4, 2003 08:32 |
