[blockMesh] error Meshing a 3D cube geometry with blockMesh |
July 13, 2009, 16:09 |
Rep Power: 16 |
HI,
I would like to create a meshing for a simple 3D cube geometry in a box with blockMesh generator. However, I got the following error : Create time Reading block mesh description dictionary Creating block mesh Creating blockCorners Creating curved edges Creating blocks Programme terminated with errors: exit code 3, status 0. Error messages: This application has requested the Runtime to terminate it in an unusual way. Please contact the application's support team for more information. terminate called after throwing an instance of 'std::bad_alloc' what(): std::bad_alloc I sent in attachement the blockMeshDict file. If someone can helping me to find the error, that would be very appreciated. GoDofLove P.S.: I use a vortices, patch, etc posted by ivanyao (How to increase Mesh near the surface of the model), but the mesh could not be opened by ParaView? |
July 13, 2009, 16:14 |
For quick view
Rep Power: 16 |
Here is the blockMesh file for quick view :
vertices ( (0 0 0) (8 0 0) (10 0 0) (24 0 0) (0 1 0) (8 1 0) (10 1 0) (24 1 0) (0 6 0) (8 6 0) (10 6 0) (24 6 0) (0 0 5) (8 0 5) (10 0 5) (24 0 5) (0 1 5) (8 1 5) (10 1 5) (24 1 5) (0 6 5) (8 6 5) (10 6 5) (24 6 5) (0 0 7) (8 0 7) (10 0 7) (24 0 7) (0 1 7) (8 1 7) (10 1 7) (24 1 7) (0 6 7) (8 6 7) (10 6 7) (24 6 7) (0 0 12) (8 0 12) (10 0 12) (24 0 12) (0 1 12) (8 1 12) (10 1 12) (24 1 12) (0 6 12) (8 6 12) (10 6 12) (24 6 12) ); blocks ( //First block group, below hex (0 1 5 4 12 13 17 16) (200 25 125) simpleGrading (1 1 1) hex (1 2 6 5 13 14 18 17) (50 25 125) simpleGrading (1 1 1) hex (2 3 7 6 14 15 19 18) (350 25 125) simpleGrading (1 1 1) //First block group, above hex (4 5 9 8 16 17 21 20) (200 125 125) simpleGrading (1 1 1) hex (5 6 10 9 17 18 22 21) (50 125 125) simpleGrading (1 1 1) hex (6 7 11 10 18 19 23 22) (350 125 125) simpleGrading (1 1 1) //Second block group, below hex (12 13 17 16 24 25 29 28) (200 25 50) simpleGrading (1 1 1) hex (14 15 19 18 26 27 31 30) (350 25 50) simpleGrading (1 1 1) //Second block group, above hex (16 17 21 20 28 29 33 32) (200 125 50) simpleGrading (1 1 1) hex (17 18 22 21 29 30 34 33) (50 125 50) simpleGrading (1 1 1) hex (18 19 23 22 30 31 35 34) (350 125 50) simpleGrading (1 1 1) //Third block group, below hex (24 25 29 28 36 37 41 40) (200 25 125) simpleGrading (1 1 1) hex (25 26 30 29 37 38 42 41) (50 25 125) simpleGrading (1 1 1) hex (26 27 31 30 38 39 43 42) (350 25 125) simpleGrading (1 1 1) //Third block group, above hex (28 29 33 32 40 41 45 44) (200 125 125) simpleGrading (1 1 1) hex (29 30 34 33 41 42 46 45) (50 125 125) simpleGrading (1 1 1) hex (30 31 35 34 42 43 47 46) (350 125 125) simpleGrading (1 1 1) ); edges ( ); patches ( patch inlet ( (0 12 16 4) (4 16 20 8) (12 24 28 16) (16 28 32 20) (24 36 40 28) (28 40 44 32) ) patch outlet ( (3 15 19 7) (7 19 23 11) (15 27 31 19) (19 31 35 23) (27 39 43 31) (31 43 47 35) ) wall upperwall ( (8 9 21 20) (9 10 22 21) (10 11 23 22) (20 21 33 32) (21 22 34 33) (22 23 35 34) (32 33 45 44) (33 34 46 45) (34 35 47 46) ) wall lowerwall ( (0 1 13 12) (1 2 14 13) (2 3 15 14) (12 13 25 24) (14 15 27 26) (24 25 37 36) (25 26 38 37) (26 27 39 38) ) wall block ( //Block //Top (17 18 30 29) //Front and Back (13 25 29 17) (14 26 30 18) //Left and Right side (25 29 30 26) (13 17 18 14) ) wall frontAndback ( //Front (0 4 5 1) (4 8 9 5) (1 5 6 2) (5 9 10 6) (2 6 7 3) (6 10 11 7) //Back (36 40 41 37) (40 44 45 41) (37 41 42 38) (41 45 46 42) (38 42 43 39) (42 46 47 43) ) ); mergePatchPairs ( ); |
July 13, 2009, 16:20 |
Henrik Rusche
Rep Power: 18 |
Dear God of Love (interesting name BTW),
I think the binaries are incompatible with your system. Try blockMesh-ing one of the tutorials, for example the cavity. Henrik |
July 13, 2009, 16:33 |
Rep Power: 16 |
I using blockMesh generator already for a 2D (b/h=2.0) rib and everything work well. I make a 2D LES simulation and everything goes right. So, I dont know why the blockMesh utilities doesn't work in 3D on my system?
blockMeshDict file for 2D (b/h=2.0) rib for personal information: vertices ( (0 0 0) (8 0 0) (10 0 0) (24 0 0) (0 1 0) (8 1 0) (10 1 0) (24 1 0) (0 6 0) (8 6 0) (10 6 0) (24 6 0) (0 0 0.03333) (8 0 0.03333) (10 0 0.03333) (24 0 0.03333) (0 1 0.03333) (8 1 0.03333) (10 1 0.03333) (24 1 0.03333) (0 6 0.03333) (8 6 0.03333) (10 6 0.03333) (24 6 0.03333) ); blocks ( hex (0 1 5 4 12 13 17 16) (200 25 1) simpleGrading (1 1 1) hex (2 3 7 6 14 15 19 18) (350 25 1) simpleGrading (1 1 1) hex (4 5 9 8 16 17 21 20) (200 125 1) simpleGrading (1 1 1) hex (5 6 10 9 17 18 22 21) (50 125 1) simpleGrading (1 1 1) hex (6 7 11 10 18 19 23 22) (350 125 1) simpleGrading (1 1 1) ); edges ( ); patches ( patch inlet ( (0 12 16 4) (4 16 20 8) ) patch outlet ( (3 15 19 7) (7 19 23 11) ) wall upperwall ( (8 9 21 20) (9 10 22 21) (10 11 23 22) ) wall lowerwall ( (0 1 13 12) (1 5 17 13) (5 6 18 17) (2 14 18 6) (2 3 15 14) ) empty frontAndBack ( (0 4 5 1) (4 8 9 5) (5 9 10 6) (2 6 7 3) (6 10 11 7) (12 16 17 13) (16 20 21 17) (17 21 22 18) (14 18 19 15) (18 22 23 19) ) ); mergePatchPairs ( ); |
July 13, 2009, 16:46 |
Henrik Rusche
Rep Power: 18 |
Dear God of Love,
I think you have been lucky not to trigger the problem with your 2D case. Please try this tutorial $FOAM_TUTORIALS/oodles/pitzDaily just to be sure ... Henrik |
July 14, 2009, 15:30 |
Rep Power: 16 |
Hi henrik,
Thank for your help. I already trying this tutorial and everything was ok. I found my mistake. I Landed with this blockMesh file : vertices ( //First plane (back of the domain) (0 0 0) (8 0 0) (10 0 0) (24 0 0) (0 1 0) (8 1 0) (10 1 0) (24 1 0) (0 6 0) (8 6 0) (10 6 0) (24 6 0) //Second plane (left side of the block) (0 0 5) (8 0 5) (10 0 5) (24 0 5) (0 1 5) (8 1 5) (10 1 5) (24 1 5) (0 6 5) (8 6 5) (10 6 5) (24 6 5) //Third plane (right side of the block) (0 0 7) (8 0 7) (10 0 7) (24 0 7) (0 1 7) (8 1 7) (10 1 7) (24 1 7) (0 6 7) (8 6 7) (10 6 7) (24 6 7) //Fourth plane (front of the domain) (0 0 12) (8 0 12) (10 0 12) (24 0 12) (0 1 12) (8 1 12) (10 1 12) (24 1 12) (0 6 12) (8 6 12) (10 6 12) (24 6 12) ); blocks ( //First block group, below hex (0 1 5 4 12 13 17 16) (200 25 5) simpleGrading (1 1 1) hex (1 2 6 5 13 14 18 17) (50 25 5) simpleGrading (1 1 1) hex (2 3 7 6 14 15 19 18) (350 25 5) simpleGrading (1 1 1) //First block group, above hex (4 5 9 8 16 17 21 20) (200 125 5) simpleGrading (1 1 1) hex (5 6 10 9 17 18 22 21) (50 125 5) simpleGrading (1 1 1) hex (6 7 11 10 18 19 23 22) (350 125 5) simpleGrading (1 1 1) //Second block group, below hex (12 13 17 16 24 25 29 28) (200 25 2) simpleGrading (1 1 1) hex (14 15 19 18 26 27 31 30) (350 25 2) simpleGrading (1 1 1) //Second block group, above hex (16 17 21 20 28 29 33 32) (200 125 2) simpleGrading (1 1 1) hex (17 18 22 21 29 30 34 33) (50 125 2) simpleGrading (1 1 1) hex (18 19 23 22 30 31 35 34) (350 125 2) simpleGrading (1 1 1) //Third block group, below hex (24 25 29 28 36 37 41 40) (200 25 5) simpleGrading (1 1 1) hex (25 26 30 29 37 38 42 41) (50 25 5) simpleGrading (1 1 1) hex (26 27 31 30 38 39 43 42) (350 25 5) simpleGrading (1 1 1) //Third block group, above hex (28 29 33 32 40 41 45 44) (200 125 5) simpleGrading (1 1 1) hex (29 30 34 33 41 42 46 45) (50 125 5) simpleGrading (1 1 1) hex (30 31 35 34 42 43 47 46) (350 125 5) simpleGrading (1 1 1) ); edges ( ); patches ( patch inlet ( (0 12 16 4) (4 16 20 8) (12 24 28 16) (16 28 32 20) (24 36 40 28) (28 40 44 32) ) patch outlet ( (3 15 19 7) (7 19 23 11) (15 27 31 19) (19 31 35 23) (27 39 43 31) (31 43 47 35) ) wall upperwall ( (8 9 21 20) (9 10 22 21) (10 11 23 22) (20 21 33 32) (21 22 34 33) (22 23 35 34) (32 33 45 44) (33 34 46 45) (34 35 47 46) ) wall lowerwall ( (0 1 13 12) (1 2 14 13) (2 3 15 14) (12 13 25 24) (14 15 27 26) (24 25 37 36) (25 26 38 37) (26 27 39 38) //Top of the block (17 18 30 29) ) wall frontAndback ( //Left and Right side of the block (13 17 18 14) (25 29 30 26) //Front and back of the block (13 25 29 17) (14 26 30 18) //Back of the domain (0 4 5 1) (4 8 9 5) (1 5 6 2) (5 9 10 6) (2 6 7 3) (6 10 11 7) //Front of the domain (36 40 41 37) (40 44 45 41) (37 41 42 38) (41 45 46 42) (38 42 43 39) (42 46 47 43) ) ); Now, it's possible to visualize the mesh with ParaView. The meshing is constant and too fine outside the boundary region so, ParaView freeze sometime. On the other hand, the meshing is too coarse in the boundary layer region and I think that need to use a ratio on the mesh like describe in the OpenFoam User's manual. I never use this fonctionality also. That gonna be a new threads! lol Thank a lot! GoDofLovE |
[snappyHexMesh] Error defining boundary layer around cube snappyHexMesh | crizpi21 | OpenFOAM Meshing & Mesh Conversion | 5 | October 16, 2021 10:56 |
[snappyHexMesh] Problem and doubts with blockMesh, snappyHexMesh and multiple geometry | luca1992 | OpenFOAM Meshing & Mesh Conversion | 0 | August 23, 2017 11:40 |
[snappyHexMesh] snappyHexMesh on sharp corners (cube) | Regis_ | OpenFOAM Meshing & Mesh Conversion | 0 | June 4, 2015 23:47 |
Why 3D solid-pore geometry showing diverged solution? | Sargam05 | OpenFOAM | 0 | December 3, 2012 15:45 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
