[Commercial meshers] Import fluent mesh
Old   July 10, 2010, 17:57
Default Import fluent mesh
Abdel
bruxellois4 is on a distinguished road
Hi everybody
i would like to import to OpenFOAM a mesh i've got in Fluent. it was done under windows (i've used fromdos), then fluentMeshtoFoam but that doesn't work, this is the error message (and you can find the .msh here http://www.2shared.com/fadmin/148774...D10D3.dat.html).
Create time
--> FOAM FATAL IO ERROR:
cannot open file
file: /home/moumen/tfe/system/controlDict at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 61.
FOAM exiting
HELP PLZZ!!
bruxellois4 is offline   Reply With Quote
Old   July 15, 2010, 11:23
Stefan Herbert
herbert is on a distinguished road
you have to run fluentMeshToFoam from inside an OpenFOAM-case with at least the system/controlDict file inside.
Regards,
Stefan
herbert is offline   Reply With Quote
Mesh Changing When Importing from Fluent russel60 OpenFOAM Running, Solving & CFD 0 February 15, 2019 16:43
Transfer of mesh from Meshing to Fluent destroys the mesh balrog_f FLUENT 9 July 28, 2018 10:02
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? RPjack ANSYS Meshing & Geometry 2 August 27, 2015 09:33
[ANSYS Meshing] Import Plot3D mesh to fluent nw_ds ANSYS Meshing & Geometry 0 May 26, 2015 11:52
[Commercial meshers] Import mesh with internal face from Fluent to openfoam 2.1.1 neeraj OpenFOAM Meshing & Mesh Conversion 1 April 29, 2013 03:54
