[Gmsh] False name of internal faceZone/faceSet by Gmsh |
November 29, 2012, 08:01 |
Hisham Elsafti
Dear Foamers,
I try to make an internal faceZone/faceSet in a Gmsh geometry. I defined a physical surface of the internal surfaces in question. I run Code:
gmsh -3 file.geo; gmshToFoam file.msh Question time: 1. Did anyone face the same problem or has anyone produced internal faceZones without this problem? 2. Is there a workaround? Best regards, Hisham |
November 29, 2012, 09:25 |
Hisham Elsafti
It seems that there is a bug in gmshToFoam. Changing:
01058 forAll(zoneFaces, zoneI) 01059 { 01060 if (zoneFaces[zoneI].size()) 01061 { 01062 label physReg = zoneToPhys[zoneI]; 01063 01064 Map<word>::const_iterator iter = physicalNames.find(physReg); 01065 01066 word zoneName = "faceZone_" + name(zoneI); 01067 if (iter != physicalNames.end()) 01068 { 01069 zoneName = iter(); 01070 } 01071 01072 Info<< "Writing zone " << zoneI << " to faceZone " 01073 << zoneName << " and faceSet" 01074 << endl; Code:
01058 forAll(zoneFaces, zoneI) 01059 { 01060 if (zoneFaces[zoneI].size()) 01061 { 01062 label physReg = patchToPhys[zoneI]; 01063 01064 Map<word>::const_iterator iter = physicalNames.find(physReg); 01065 01066 word zoneName = "faceZone_" + name(zoneI); 01067 if (iter != physicalNames.end()) 01068 { 01069 zoneName = iter(); 01070 } 01071 01072 Info<< "Writing zone " << zoneI << " to faceZone " 01073 << zoneName << " and faceSet" 01074 << endl; Regards, Hisham |
faceset, facezone, gmsh, gmshtofoam, internal face |
using chemkin | JMDag2004 | OpenFOAM Pre-Processing | 2 | March 8, 2016 22:38 |
[Gmsh] Internal faces from gmsh how to create patches in OpenFoam | podallaire | OpenFOAM Meshing & Mesh Conversion | 27 | April 25, 2012 21:24 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
