[snappyHexMesh] Multi region meshing & recovering the original patch names
Like Tree1Likes
  • 1 Post By wyldckat
Old   March 24, 2010, 07:01
Default Multi region meshing & recovering the original patch names
fluidpath is on a distinguished road
Hello All,
I have been trying to do some multi region (multi volume) using snappyHexMesh (sHM) with a simple two boxes side by side geometry. I am struggling with getting it to work, in terms of getting 2 distinct volume regions and recovering my original geometry patches. I've attached a tiny tar archive of the case for reference.
I started with the following individual STL files :-
box01.stl (5 out of 6 faces of a closed box)
baffle01.stl (common wall between the two box volumes)
box02.stl (5 out of 6 faces of a closed box)
baffle02.stl (copy of baffle01.stl but with flipped normals)
I then edited the individual STL files and post-fixed the "solid" and "endsolid" keywords with the desired region name :-
box01_baffle01
box01_box01
box02_baffle02
box02_box02
These four individual files were then concatenated together to form the final 2 closed volume multi region STL parts :-
cat box01.stl baffle01.stl > fluid_box01.stl
cat box02.stl baffle02.stl > fluid_box02.stl
As a side note I found that I couldn't recover the correct two volumes if the normals weren't consistently facing outward for each volume (I am guessing inward normals would also work).
In the sHM dictionary (under refinementSurfaces{} ) I defined the following 2 face and 2 cell zone names in order to extract the 2 regions (the key geometry{} & refinementsurfaces{} sections are posted at the bottom of this message for convenience) :-
fluid_box01_fz
fluid_box01_cz
fluid_box02_fz
fluid_box02_cz
I then ran blockMesh (whose extents are purposefully larger than those of the STL geometry) and sHM on the case before running "splitMeshRegions -cellZones" utility. This recovers nicely the 3 distinct regions in my case - fluid_box01_cz, fluid_box02_cz and domain0 which contains the remaining volume cells, outside of the 2 box STL geometry.
The following lists the resulting patches for each of the 3 recovered regions :-
"domain0" boundary patches
minX
maxX
minY
maxY
minZ
maxZ
domain0_to_fluid_box01_cz
domain0_to_fluid_box02_cz
"fluid_box01_cz" boundary patches
fluid_box01_cz_to_domain0
fluid_box01_cz_to_fluid_box02_cz
"fluid_box02_cz" boundary patches
fluid_box02_cz_to_fluid_box01_cz
fluid_box02_cz_to_domain0
My question is how can I preserve or recover the original patch region names that I specified in the 2 STL files. As you can see from above I currently end up with names along the lines of "cellZone A_to_cellZoneB". This test case only had two region patches in each of the 2 closed STL files so a simple renaming operation could be used. However, if each of the 2 closed STL files had 6 region patch names (i.e. 1 per box side) then I think you would still only get the above list of resulting patches?
Am I correct in thinking that sHM cannot use many separate STL files to do multi region meshing, unless the separate regions are wholely contained inside a single closed volume stl file? So if you had a box shaped region that you wanted meshed and this was contained in 2 separate stl files this would not work.
Thank you for any help or assistance you can give me!
geometry
fluid_box01.stl
type triSurfaceMesh;
//cannot use name with regions
// name fluid_box01;
regions
box01_box01 // Named region in the STL file
name box01_box01; // User-defined patch name
box01_baffle01
name box01_baffle01;
fluid_box02.stl
// name fluid_box02;
regions
box02_box02 // Named region in the STL file
name box02_box02; // User-defined patch name
box02_baffle02
name box02_baffle02;
refinementSurfaces
fluid_box01.stl
// Surface-wise min and max refinement level
level (1 1);
faceZone fluid_box01_fz;
cellZone fluid_box01_cz;
zoneInside true;
regions
level (1 1); // User-defined patch name
box01_baffle01
level (1 1);
fluid_box02.stl
level (1 1);
faceZone fluid_box02_fz;
cellZone fluid_box02_cz;
zoneInside true;
regions
box02_baffle02
level (1 1);
fluidpath is offline   Reply With Quote
Old   May 17, 2013, 17:01
Default Nobody knows the solution?
Jackie Chou
jackeyhust is on a distinguished road
I had the same problem. Could anybody give some solution? thanks a lot!
jackeyhust is offline   Reply With Quote
Old   May 19, 2013, 06:08
Retired Super Moderator
Bruno Santos
Greetings to all! Jackie, welcome to the forum!
@Jackie: I got your email about this thread. I know I've either answered to this question in the past or I've already seen the answer in the forum. But after 15 minutes of searching, I can't find it.
Either way, try reading the following threads for ideas:
Best regards,
Bruno
jackeyhust likes this.
Old   May 19, 2013, 06:33
Daniel Pielmeier
billie is on a distinguished road
I want do do the same thing with sHM and I searched the forums up and down but could not find a solution.
I think original patches are preserved if there is one region and a blockMesh which is larger than than the actual geometry but not if you have multiple regions.
I tried with a simple test case, a short pipe with only a subset of the solid walls as separate patch where a heat flux should be applied but the original patch is not preserved by sHM. I can share the case and upload it next week if anyone wants to take a look at it.
billie is offline   Reply With Quote
Old   May 19, 2013, 19:13
Default Thank you so much!
Jackie Chou
Best regards,
Bruno
Hi, Bruno,
it's really kind of you! I read your recommended post. That's quite nice and useful. I will try it and give you the feedback.
regards,
Jackie
multi, patch, recovering, region, snappyhexmesh
[cfMesh] and Multi Region Meshing aminem OpenFOAM Community Contributions 11 July 26, 2022 02:50
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 07:30
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
