January 12, 2007, 14:27 |
GmshToFoam basic question
Trinia Dzurny
I am attempting to use the gmshToFoam utility for the first time and am getting an error. I was wondering if someone could point me in the right direction. Here is what I did:
(1) Created a new case <gmsh> using FoamX. (2) Found the file "CubeVer1.msh" that came with the OpenFOAM installation and verified that it could be read by Gmsh. (3) Copied "CubeVer1.msh" to the root directory of my new <gmsh> case and also copied it to gmsh/constant/polymesh. I wasn't sure if the *.msh file needed to be in the /polymesh directory. (4) Invoked the gmshToFoam utility from FoamX and from the command line. Here is the error message I get: Exec : gmshToFoam /home/tmolls/OpenFOAM/tmolls-1.3/run/test gmsh CubeVer1.msh Date : Jan 12 2007 Time : 11:17:05 Host : cfd01 PID : 9442 Root : /home/tmolls/OpenFOAM/tmolls-1.3/run/test Case : gmsh Nprocs : 1 Create time --> FOAM FATAL IO ERROR : Attempt to get back from bad stream file: CubeVer1.msh at line 1. From function void Istream::getBack(token& t) in file db/IOstreams/IOstreams/Istream.C at line 44. FOAM exiting -------------------------------------- Can anybody help me out and let me know what I am doing wrong? Thanks in advance. |
August 30, 2009, 17:52 |
Steve Hansel
I got that error when I typed the wrong mesh file name in the command.
Basic question on motorBike tutorial | newToOpenFoam | OpenFOAM Running, Solving & CFD | 2 | July 14, 2011 09:50 |
[Gmsh] A basic Gmsh question: 1D transfinite | the_phew | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2011 10:58 |
Basic question to buoyantBoussinesqPisoFoam | kriz | OpenFOAM | 2 | June 12, 2010 03:35 |
Basic Question | Abhi | FLUENT | 1 | August 4, 2007 08:07 |
Basic question: UDF for wall heat flux | Carl | FLUENT | 1 | August 5, 2006 19:01 |
