[blockMesh] Error in BlockMesh: inconsistent number of faces
Old   August 19, 2010, 03:48
Question Error in BlockMesh: inconsistent number of faces
pc1
pc1 is on a distinguished road
Hi there,
I'm trying to develop a trapezoidal-shaped channel in BlockMesh, consisting of 2 three-sided prism and in between a normal cuboid. In the attached PDF-file you can find a sketch of the geometry.
Below the blockMesh is posted.
My problem is that when I'm trying to define different number of cells in x and in y direction like for example:
blocks
( hex (3 2 2 3 7 6 5 4) (1300 50 10) simpleGrading (1 1 1)
hex (3 9 8 2 7 11 10 6) (1300 50 10) simpleGrading (1 1 1)
hex (8 9 9 8 10 11 15 14) (1300 50 10) simpleGrading (1 1 1))
I get the following error:
Inconsistent number of faces between block pair 0 and 1
From function blockMesh::createMergeList()
in file createMergeList.C at line 196.
FOAM exiting
If I define the mesh as follows:
blocks
( hex (3 2 2 3 7 6 5 4) (100 100 10) simpleGrading (1 1 1)
100 100 10) simpleGrading (1 1 1))
everything works fine.
Can anyone tell me how to solve this problem? I don't know what I have to change to get this working.
I'm thankful for any advice.
Regards,
pc1
my BLOCKMESH:
| \\ / O peration | Version: 1.5 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1.;
vertices
(0 0 0) // 0
(0 40 0) // 1
(0.48 40 0) // 2
(0.48 0 0) // 3
(0 0 0.16) // 4
(0 40 0.16) // 5
(0.48 40 0.16) // 6
(0.48 0 0.16) // 7
(1.72 40 0) // 8
(1.72 0 0) // 9
(1.72 40 0.16) // 10
(1.72 0 0.16) // 11
(2.2 40 0) // 12
(2.2 0 0) // 13
(2.2 40 0.16) // 14
(2.2 0 0.16) // 15
blocks
hex (3 2 2 3 7 6 5 4) (1 1 1) simpleGrading (1 1 1) // p
hex (3 9 8 2 7 11 10 6) (1 1 1) simpleGrading (1 1 1) //q
hex (8 9 9 8 10 11 15 14) (1 1 1) simpleGrading (1 1 1) // r
edges
patches
//left: Prism p
wall xminp
(4 5 2 3)
patch yminp
(3 7 4 3)
patch ymaxp
(2 5 6 2)
patch zminp
(3 2 2 3)
patch zmaxp
(4 7 6 5)
// middle: cuboid q
patch yminq
(7 11 9 3)
patch ymaxq
(6 2 8 10)
wall zminq
(2 3 9 8)
patch zmaxq
(11 7 6 10)
// right: Prism r
wall xmaxr
(15 9 8 14)
patch yminr
(15 11 9 15)
patch ymaxr
(14 8 10 14)
patch zmaxr
(15 14 10 11)
patch zminr
(8 9 9 8)
mergePatchPairs
pc1 is offline   Reply With Quote
Old   August 19, 2010, 06:11
Martin
MartinB will become famous soon enough
Hi pc1,
there are numbering problems in your blockMeshDict.
Try this one:
FoamFile
version 2.0;
format ascii;
class dictionary;
convertToMeters 1.;
vertices
(0 0 0) // 0
(0 40 0) // 1
(0.48 40 0) // 2
(0.48 0 0) // 3
(0 0 0.16) // 4
(0 40 0.16) // 5
(0.48 40 0.16) // 6
(0.48 0 0.16) // 7
(1.72 40 0) // 8
(1.72 0 0) // 9
(1.72 0 0.16) // 11
(2.2 40 0) // 12
(2.2 0 0) // 13
(2.2 40 0.16) // 14
(2.2 0 0.16) // 15
blocks
hex (4 3 2 5 4 7 6 5) (1300 50 10) simpleGrading (1 1 1) // p
hex (3 9 8 2 7 11 10 6) (1300 50 10) simpleGrading (1 1 1) //q
hex (9 15 14 8 11 15 14 10) (1300 50 10) simpleGrading (1 1 1) // r
edges
patches
//left: Prism p
wall xminp
(4 3 2 5)
patch yminp
(4 3 7 4)
patch ymaxp
(2 6 5 2)
//patch zminp
//(3 2 2 3)
patch zmaxp
(4 7 6 5)
// middle: cuboid q
patch yminq
(3 9 11 7)
patch ymaxq
(2 8 10 6)
wall zminq
(3 9 8 2)
patch zmaxq
(7 11 10 6)
// right: Prism r
wall xmaxr
(9 15 14 8)
patch yminr
(9 15 15 11)
patch ymaxr
(14 10 8 14)
patch zmaxr
(11 15 14 10)
//patch zminr
//(8 9 9 8)
mergePatchPairs
I removed the interior walls, too.
Martin
MartinB is offline   Reply With Quote
Old   August 19, 2010, 09:19
Question Same error occured again
pc1
Hello Martin,
thanks for your reply. I just tested to turn the numbers as you proposed and removed the "interior" walls. Unfortunately I still get the same Error:
Create time
Creating block mesh from
    "*********/mesh/constant/polyMesh/blockMeshDict"
Creating blockCorners
Creating curved edges
Creating blocks
Creating patches
Creating block mesh topology
Default patch type set to empty
--> FOAM Warning :
    From function polyMesh::polyMesh(... construct from shapes...)
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 577
    Found 2 undefined faces in mesh; adding to default patch.
Check block mesh topology
    Basic statistics
        Number of internal faces : 2
        Number of boundary faces : 14
        Number of defined boundary faces : 14
        Number of undefined boundary faces : 0
    Checking patch -> block consistency
Creating block offsets
Creating merge list
FOAM exiting
The first Warning appears because of the removed walls, which are not really walls but rather edges. In a test with a single three-sided prism I found out that I have to define them.
The shifting of the numbers doesn't have any effect on the result.
The biggest problem is the inconsistent number of faces between the blocks. Still have no idea how to solve it.
Any proposals?
Regards,
pc1
Old   August 19, 2010, 09:40
Martin
after adding
empty dummies
  (4 5 5 4)
  (15 14 14 15)
to the patches definition, the warning disappears... however the command
checkMesh -allTopology -allGeometry
gives under-dermined cells :-(
Does it run anyway?
Martin
Old   August 19, 2010, 09:45
Martin
And did you really tried my blockMeshDict? I don't have the inconsistent number of faces problem here...
Old   August 19, 2010, 13:12
Default tried your BlockMeshDict and checkMesh, both failed
pc1
I did try your BlockMeshDict, but unfortunately BlockMesh aborted because of the inconsistent number of cells. Don't know why you don't have the same problem with the BlockMesh?
My CheckMesh also failed.
Is there an other possibility to define such a geometry in the BlockMeshDict?
Or does anyone else have some advice for me?
Tomorrow I'll continue searching for the reason of this error...
pc1
Old   August 19, 2010, 17:37
Martin
What about this idea:
FoamFile
version 2.0;
format ascii;
class dictionary;
convertToMeters 1.;
vertices
(0 0 0) // 0
(0 40 0) // 1
(0.48 40 0) // 2
(0.48 0 0) // 3
(0 0 0.16) // 4
(0 40 0.16) // 5
(0.48 40 0.16) // 6
(0.48 0 0.16) // 7
(1.72 40 0) // 8
(1.72 0 0) // 9
(1.72 0 0.16) // 11
(2.2 40 0) // 12
(2.2 0 0) // 13
(2.2 40 0.16) // 14
(2.2 0 0.16) // 15
(0.6 0 0.08) // 16
(0.6 40 0.08) // 17
(1.6 0 0.08) // 18
(1.6 40 0.08) // 19
blocks
hex (5 6 7 4 2 17 16 3) block1 (11 1300 10) simpleGrading (1 1 1) // p
hex (2 17 16 3 8 19 18 9) block2 (11 1300 50) simpleGrading (1 1 1) //q
hex (17 6 7 16 19 10 11 18) block3 (10 1300 50) simpleGrading (1 1 1) // r
hex (10 14 15 11 19 8 9 18) block4 (11 1300 10) simpleGrading (1 1 1) // s
edges
patches
patch xFront
  (4 3 16 7)
  (3 9 18 16)
  (9 15 11 18)
  (16 18 11 7)
patch xBack
  (5 2 17 6)
  (2 8 19 17)
  (17 19 10 6)
  (8 14 10 19)
patch yLeft
  (3 2 5 4)
patch yRight
  (8 9 15 14)
patch zBottom
  (3 9 8 2)
patch zTop
  (4 7 6 5)
  (7 11 10 6)
  (11 15 14 10)
mergePatchPairs
The patch names and patch shapes are different to your first solution... but no warnings and no checkMesh problems...
Martin
Old   August 20, 2010, 06:24
Smile
pc1
Great!
That one works fine! Thank you for your help!!!
Regards,
pc1
blockmesh, number of faces
[snappyHexMesh] Layers not growing at all zonda OpenFOAM Meshing & Mesh Conversion 12 June 6, 2020 11:28
[snappyHexMesh] SHM is not extruding/adding Layers everywhere matthiasd OpenFOAM Meshing & Mesh Conversion 2 October 16, 2016 16:45
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
AMI interDyMFoam for mixer danny123 OpenFOAM Running, Solving & CFD 4 June 19, 2013 04:49
