[Other] create a complex 2D mesh
Old   August 5, 2010, 06:14
Default create a complex 2D mesh
Florian Becker
draufunddran is on a distinguished road
Hallo,
i want to create a relative complex 2D mesh for OpenFOAM (still 3D but with one cell in z-direction). I know i can do this with blockMesh, but since my geometry is very complex i am searching for a solution where i can create it a little bit simpler than just hacking all the points and stuff in the blockMeshDict.
Is it possible to make a pseudo 2D mesh with snappyHexMesh?
greetings from Munich, Germany...
draufunddran
draufunddran is offline   Reply With Quote
Old   August 5, 2010, 08:23
Nima Samkhaniani
nimasam is on a distinguished road
hi friend
look at following website , its a free software for mesh creating and work with openFoam and its easy to work
http://www.discretizer.org/
nimasam is offline   Reply With Quote
Old   August 5, 2010, 08:53
Florian Becker
hi nimasam,
thank you for your fast answer, i will look at this and hopefully report my success...
greetz
draufunddran
Old   August 9, 2010, 10:11
Florian Becker
Hallo,
i have tried some thinks with Discretizer, but i think its not what i'm looking for. I can't make a 2D-mesh of an airfoil.
Some informations on my case:
I need to calculate the drag and lift of different 2D-airfoils with OpenFOAM and i don' have any commercial meshing applications. Are there any other free meshing tools out there?
Thanks for your support...
draufunddran
Old   August 17, 2010, 23:55
darioth's Avatar
Darío Montes
darioth is on a distinguished road
Send a message via MSN to darioth Send a message via Skype™ to darioth
Dear Draufunddran:
Have you tried with Gmsh? I 'm experimenting a little bit with gmsh trying to calculate the velocity field with potentialFoam with no good results to the NACA0015 airfoil.
My test: inlet = 10m/s, slip conditions and the cp should be near -0.57 so I should obtain velocities over the airfoil 25% over than Uinf.
I can email you my results.
Regards
Darío Montes
skype: dariotecnoedu
darioth is offline   Reply With Quote
Old   August 20, 2010, 13:50
Florian Becker
hallo darioth,
i will try it with gmsh on Monday, and i will be happy if you could email your results too me.
greetings,
Florian
Salome, how to create non-structurd mesh to compound with structured one? sheaker Mesh Generation & Pre-Processing 8 August 11, 2017 14:47
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[snappyHexMesh] snappyHexMesh does not create mesh in body volume Illmatic OpenFOAM Meshing & Mesh Conversion 1 July 11, 2016 21:35
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
