[Gmsh] Physical Group Meshing
Old   June 17, 2011, 13:11
Default Physical Group Meshing
Daniel
Daniel_L is on a distinguished road
Hello everyone.
Using GMSH, I was recently able to create a tetrahedral mesh of a tube's surfaces without implementing physical groups. However, when I introduced physical groups to the .geo code, using 2D meshing resulted in only the physical group points being visible! Is there any way to create a mesh that includes both ungrouped surfaces and grouped points?
Thank you very much.
Daniel_L is offline   Reply With Quote
Old   June 26, 2011, 02:46
Jinbiao Xiong
JinBiao is on a distinguished road
Send a message via MSN to JinBiao
I am not sure that I have got your question. If you want both the points and surfaces included, you can just group the surfaces as a physical surfaces. For how to do it, you can find it easily from the tutorial for GMSH.
Jinbiao
Jinbiao
JinBiao is offline   Reply With Quote
[Gmsh] "Perhaps you have not exported the 3D elements?" j_moulton OpenFOAM Meshing & Mesh Conversion 14 October 6, 2022 21:58
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
Are my IRIXbs systune parametersb setting correct lakeat OpenFOAM Installation 1 May 5, 2008 10:48
Heat balance in radiation simulation Rivera Phoenics 1 January 6, 2006 17:51
