[Commercial meshers] case File with a polyhedral mesh to OpenFoam
Old   February 20, 2013, 07:10
Default case File with a polyhedral mesh to OpenFoam
Christoph_84 is on a distinguished road
Hallo,
I got a fluent case file with a polyhedral mesh and two cellzones is there any possibility to convert this to OpenFoam?
I tried fluentMeshToFoam and got this:
  Found end of section in unknown:)
 Number of cells: 3567963
 number of faces: 18573112
 Number of points: 14183558
 Found unknown block:(3012
 Embedded blocks in comment or unknown: (
 0Dimension of grid: 40
 (Dimension of grid: 14
 Dimension of grid: 1733
 eDimension of grid: 8
 Dimension of grid: 5
 (Dimension of grid: 15
 eDimension of grid: 9
 Dimension of grid: 36715
 bDimension of grid: 5
 Found unknown block:(3013
 Found end of section in unknown:%
 �Found end of section in unknown:#
with fluent3DMeshToFoam:
Create time
 Number of faces: 18573112
 --> FOAM Warning : Found unknown block of type: "3012"
     on line 3744
     on line 3747
 --> FOAM FATAL ERROR:
 Do not understand characters:
     on line 3748
     From function fluentMeshToFoam::lexer
     in file fluent3DMeshToFoam.L at line 746.
 FOAM exiting
I can convert the Mesh file with fluent3DMeshToFoam, but this is tet/hex and not polyhedral and checkMesh look like this:
Create time
 Create polyMesh for time = 0
 Time = 0
 Mesh stats
 checkMesh: malloc.c:3546: munmap_chunk: Assertion `ret == 0' failed.
If I use fluentMeshToFoam on the mesh file i got this error:
 FINISHED LEXING
 dimension of grid: 3
 Creating shapes for 3-D cells
 Cannot find match for first face. cell model: tet first model face: 3(1 2 3) Mesh faces:
 4
 0()
 0()
 0()
 0()
     From function create3DCellShape(const label cellIndex, const labelList& faceLabels, const labelListList& faces, const labelList& owner, const labelList& neighbour, const label fluentCellModelID)
     in file create3DCellShape.C at line 185.
Has anyone an Idea?
Christoph_84 is offline   Reply With Quote
Old   February 25, 2013, 17:24
Retired Super Moderator
Bruno Santos
Greetings Christoph_84,
Try the instructions provided here: http://www.cfd-online.com/Forums/ope...tml#post346373 post #9
Best regards,
Bruno
Old   April 26, 2013, 10:07
anonymous
jcn2013 is on a distinguished road
Hi Christoph,
Have you converted your mesh to ascii?
Regards,
Josh
jcn2013 is offline   Reply With Quote
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 08:06
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
