[blockMesh] block merging with blockMesh
Old   October 21, 2014, 03:16
Default block merging with blockMesh
vaina74 is on a distinguished road
Hi, I need to merge more blocks in order to model a room with inlet and outlet openings. I start with a very simplified case, just to set a preliminary case (see model.png).
I'm in doubt with mergePatchPairs and patch settings.
1. Should I define master and slave patches (see blockMesh)?
2.The inlet and outlet block faces don't match the whole face of the room block: how the wall boundary condition (and p and U values) is applied to the not-overlapped area of the bigger block?
Thanks for your help.
vaina74 is offline   Reply With Quote
[blockMesh] blockMesh error - Negative Volume Block adoledin OpenFOAM Meshing & Mesh Conversion 2 June 22, 2016 10:44
[blockMesh] blockMesh merging ancolli OpenFOAM Meshing & Mesh Conversion 4 May 13, 2016 18:11
[blockMesh] External flow around cube with blockMesh Woody8 OpenFOAM Meshing & Mesh Conversion 0 March 31, 2015 14:54
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 02:58
blockMesh: block with 6 vertexes dani OpenFOAM 3 June 25, 2009 13:13
