May 30, 2019, 11:43 |
Refined Mesh Gmsh
Jacques
Hello everyone,
I have a little issue creating my unstructured mesh on gmsh. I would like to simulate a pipe flow and for that I need to refine the Walls of the pipe, in order to have more accurate calculations at the edge and larger calculations at the center. I tried with "Transfinite" but as soon as I put both edges (Top & Bottom) as "Transfinite curve", I just get the same small mesh everywhere. I've heard there might be a way with "Field[] = Attractor", but I couldnt figure it out yet... Any Idee? Thanks! Edit: I have managed to create the mesh and refine on both edges, but as soon as I try to gather them together with the commands : Field[] = Min; Field[].FieldsList = { , }; Background Field = ; , the result is a very fine mesh over the entire surface (except at Inlet and Outlet) Last edited by toba; May 30, 2019 at 13:44. Reason: further researchs |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] Multi Region Mesh of a car filter | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 3 | September 11, 2019 19:34 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
