[CAD formats] Stl file export
Old   January 9, 2013, 12:04
Default Stl file export
Sha Huang
Joanna Huang is on a distinguished road
Hello, everyone:
I wonder what software is the best to export .stl file which is used in openFoam.
The .stl file I need contain many patchs/regions with different names, but I don't know how to specipy it, The Catia sofeware can just export one solid. How Can I deal with it.
Joanna Huang is offline   Reply With Quote
Old   January 9, 2013, 20:19
Doug68 is on a distinguished road
I've read what you need to do is create separate STL in ASCII format then you can edit them together into one STL file. The header part for each section then being used for the patch name.
This is something I've yet to try myself so I hope I'm not telling you garbage.
Doug68 is offline   Reply With Quote
Old   January 10, 2013, 05:21
Sha Huang
Thank you so much for your reply, I will try that. So there isn't any simple way to export it at one time.
Old   January 10, 2013, 05:47
Retired Super Moderator
Bruno Santos
Greetings to all!
Blender and Meshlab are the usual favourites for manipulating STL files.
Best regards,
Bruno
Old   January 10, 2013, 07:08
Sha Huang
Originally Posted by wyldckat View Post
Greetings to all!
Best regards,
Bruno
But Blender can not import .igs file which is not every convinient, right? And can blender specify different parts name and export .stl file at one time?
Old   January 10, 2013, 16:21
Bruno Santos
Both Blender and Meshlab can import STL. Then you can manipulate the STL and export in parts.
Ah, I had almost forgotten about this tutorial: http://openfoamwiki.net/index.php/Tut_andrew_blender - it's a bit outdated, since it was made when Blender was still on 2.49b, if I'm not mistaken.
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 14:30
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 18:13
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 21:03
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 11:32
