[snappyHexMesh] Dumping cell as obj
Like Tree1Likes
  • 1 Post By wyldckat
Old   April 11, 2013, 05:07
Cool Dumping cell as obj
Lana is on a distinguished road
Hi All,
I tried sHM my external flow model.
What I got is this error
Surface refinement iteration 0
Marked for refinement due to surface intersection : 0 cells.
Marked for refinement due to curvature/regions : 14 cells.
Determined cells to refine in = 0.22 s
Selected for refinement : 14 cells (out of 165486)
hexRef8 : Dumping cell as obj to "/home/cnf0550/0304/cell_21677.obj"
--> FOAM FATAL ERROR:
nAnchors:2 faceI:502672
From function createInternalFaces(..)
in file polyTopoChange/polyTopoChange/hexRef8.C at line 1277.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/ linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/lib OpenFOAM.so"
#2 Foam::hexRef8::createInternalFaces(Foam::List<Foam ::List<int> > const&, Foam::List< Foam::List<int> > const&, Foam::List<int> const&, Foam::List<int> const&, Foam::List<in t> const&, Foam::List<int> const&, int, Foam:olyTopoChange&) const in "/usr/local/Ope nFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libdynamicMesh.so"
#3 Foam::hexRef8::setRefinement(Foam::List<int> const&, Foam:olyTopoChange&) in "/us r/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libdynamicMesh.so"
#4 Foam::meshRefinement::refine(Foam::List<int> const&) in "/usr/local/OpenFOAM/OpenFO AM-1.6.x/lib/linux64GccDPOpt/libautoMesh.so"
#5 Foam::meshRefinement::refineAndBalance(Foam::strin g const&, Foam::decompositionMeth od&, Foam::fvMeshDistribute&, Foam::List<int> const&, double) in "/usr/local/OpenFOAM/O penFOAM-1.6.x/lib/linux64GccDPOpt/libautoMesh.so"
#6 Foam::autoRefineDriver::surfaceOnlyRefine(Foam::re finementParameters const&, int) i n "/usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libautoMesh.so"
#7 Foam::autoRefineDriver::doRefine(Foam::dictionary const&, Foam::refinementParameter s const&, bool, Foam::dictionary const&) in "/usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/lin ux64GccDPOpt/libautoMesh.so"
#8 main in "/usr/local/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/snappy HexMesh"
#9 __libc_start_main in "/lib64/libc.so.6"
#10 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versi onNumber, Foam::IOstream::compressionType) const in "/usr/local/OpenFOAM/OpenFOAM-1.6.x /applications/bin/linux64GccDPOpt/snappyHexMesh"
Abort
What should I do nest to get my sHM working? Help!
Lana is offline   Reply With Quote
Old   April 14, 2013, 09:11
Retired Super Moderator
Bruno Santos
Greetings Lana,
You're not providing much information to work with... from the error message, I can only assume that it's having trouble with meshing around a highly detailed part of the geometry, which leads to problems. Or the geometry is has some flaws that are hard to work with.
And you're using OpenFOAM 1.6.x ? Is there any chance you can upgrade to OpenFOAM 2.2? Because snappyHexMesh is a lot better in OpenFOAM 2.2...
Best regards,
Bruno
PS: I suggest that you read this thread: How to give enough info to get help
tikulju likes this.
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
Neighboring cells in tetrahedral mesh vishwesh OpenFOAM Programming & Development 9 November 10, 2017 07:06
Partition: cell count = 0 metmet FLUENT 1 August 31, 2014 19:41
monitoring cell Jane Siemens 2 March 4, 2004 21:01
cell to cell relation CMB Siemens 1 December 4, 2003 04:05
