May 28, 2013, 07:45 |
file modification
belkadi
Rep Power: 12 |
Dear all,
I post this message in order to obtain a help. I'm beginners with openfoam, I've just created a mesh for a basic structure (left image in the attached file). I'm wondering if you can help to add some features to obtain the right image of the attached file . Here my original code for the mesh /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.001; vertices ( (0 -25.4 -15) (0 -5 -15) (0 0 -15) (0 3 -15) (0 12.7 -15) (0 25.4 -15) (206 -25.4 -15) (206 -8.5 -15) (206 0 -15) (206 6.5 -15) (206 17 -15) (206 25.4 -15) (290 -16.6 -15) (290 -6.3 -15) (290 0 -15) (290 4.5 -15) (290 11 -15) (290 16.6 -15) (0 -25.4 15) (0 -5 15) (0 0 15) (0 3 15) (0 12.7 15) (0 25.4 15) (206 -25.4 15) (206 -8.5 15) (206 0 15) (206 6.5 15) (206 17 15) (206 25.4 15) (290 -16.6 15) (290 -6.3 15) (290 0 15) (290 4.5 15) (290 11 15) (290 16.6 15) ); blocks ( // hex (0 6 7 1 22 28 29 23) (18 7 1) simpleGrading (0.5 1.8 1) // hex (1 7 8 2 23 29 30 24) (18 10 1) simpleGrading (0.5 4 1) // hex (2 8 9 3 24 30 31 25) (18 13 1) simpleGrading (0.5 0.25 1) //hex (0 10 11 5 26 32 33 27) (180 18 1) simpleGrading (4 1 1) hex (0 6 7 1 18 24 25 19 ) (1 1 1) simpleGrading (1 1 1) hex (1 7 8 2 19 25 26 20) (1 1 1) simpleGrading (1 1 1) hex (2 8 9 3 20 26 27 21) (1 1 1) simpleGrading (1 1 1) hex (3 9 10 4 21 27 28 22) (1 1 1) simpleGrading (1 1 1) hex (4 10 11 5 22 28 29 23) (1 1 1) simpleGrading (1 1 1) hex (6 12 13 7 24 30 31 25) (1 1 1) simpleGrading (1 1 1) hex (7 13 14 8 25 31 32 26) (1 1 1) simpleGrading (1 1 1) hex (8 14 15 9 26 32 33 27) (1 1 1) simpleGrading (1 1 1) hex (9 15 16 10 27 33 34 28) (1 1 1) simpleGrading (1 1 1) hex (10 16 17 11 28 34 35 29) (1 1 1) simpleGrading (1 1 1) ); edges ( arc 0 1 (-1 3 0.0) arc 1 2 (-1 3 0.0) arc 2 3 (-1 3 0.0) arc 3 4 (-1 3 0.0) arc 4 5 (-1 3 0.0) ); patches ( ); // ************************************************** *********************** // If you have any suggestions please contact me ! Many thanks Kind regards Belkadi |
June 3, 2013, 14:03 |
Nima Samkhaniani
Rep Power: 24 |
you can create a base mesh (a slice of domain), then use extrudeMesh utility at OpenFOAM to create the whole domain
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
