August 5, 2013, 07:12 |
polyDualMesh -- Error
Aditya
Rep Power: 13 |
Hello
I recently came across this polyDualMesh which can convert tet mesh from snappyHexMesh to polygonal mesh. I am trying to get this function working but, I have this problem every time : HTML Code:
--> FOAM FATAL ERROR: Created illegal face 2(4472123 4472125) at position:16171367 when filtering removed points From function polyTopoChange::compact(..) in file polyTopoChange/polyTopoChange/polyTopoChange.C at line 1056. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) addr2line failed #1 Foam::error::abort() addr2line failed Can any one suggest me or explain me why I am getting this error... ? I am trying to mesh a blower. I have successfully completed meshing it with SnappyHex. there are some highly skewed faces may be 2 or 3 our of 17Million faces. Please help me clear this error. Thanks in advance. |
August 8, 2013, 22:04 |
Thomas Smyth
Rep Power: 16 |
I've just come across exactly the same error and would be interested if you or anyone else has found a solution.
Cheers, Thom |
November 21, 2013, 05:43 |
Albrecht vBoetticher
Rep Power: 16 |
I wonder, too, the same can happen with stitchMesh...
November 22, 2013, 03:49 |
#4 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
But so far, I have not yet been successful in doing this myself. Although there are two OpenFOAM utilities that might help:
With stitchMesh, things can be rather different. More information about the mesh where you are having this problem would come in handy. Best regards, Bruno
November 22, 2013, 04:33 |
Rep Power: 16 |
Thanks Bruno, I didn't know about modifyMesh. I increased in my case the resolution of the coarser mesh part such that the cell width at the patches for stitch mesh get the ratio 2:1, and it worked fine.
Best wishes, Albrecht |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
