October 16, 2013, 06:02 |
Error in SnappyHexMesh
Reza
Hi Friends,
I'm doing snappyHexMesh on a .stl file. when I change the location of inside point, to mesh inside of my object, the following error appears. Thank you in advance for your helpful comments. Error: Doing final balancing --------------------- Found 0 zoned faces to keep together. [1] [2] #0 [3] #0 Foam::error:rintStack(Foam::Ostream&)Foam::error :rintStack(Foam::Ostream&)[0] #0 Foam::error:rintStack(Foam::Ostream&)#0 Foam::error:rintStack(Foam::Ostream&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [1] #1 Foam::sigFpe::sigHandler(int) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [3] #1 Foam::sigFpe::sigHandler(int) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [0] #1 Foam::sigFpe::sigHandler(int) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [2] #1 Foam::sigFpe::sigHandler(int) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [3] #2 Uninterpreted: [3] #3 Foam::hierarchGeomDecomp::calculateSortedWeightedS izes(Foam::List<int> const&, Foam::List<int> const&, Foam::Field<double> const&, int, Foam::Field<double>&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [1] #2 Uninterpreted: [1] #3 Foam::hierarchGeomDecomp::calculateSortedWeightedS izes(Foam::List<int> const&, Foam::List<int> const&, Foam::Field<double> const&, int, Foam::Field<double>&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [0] #2 Uninterpreted: [0] #3 Foam::hierarchGeomDecomp::calculateSortedWeightedS izes(Foam::List<int> const&, Foam::List<int> const&, Foam::Field<double> const&, int, Foam::Field<double>&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [2] #2 Uninterpreted: [2] #3 Foam::hierarchGeomDecomp::calculateSortedWeightedS izes(Foam::List<int> const&, Foam::List<int> const&, Foam::Field<double> const&, int, Foam::Field<double>&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so" [1] #4 Foam::hierarchGeomDecomp::sortComponent(int, Foam::Field<double> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int> const&, unsigned char, int, Foam::List<int>&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so" [0] #4 Foam::hierarchGeomDecomp::sortComponent(int, Foam::Field<double> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int> const&, unsigned char, int, Foam::List<int>&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so" [2] #4 Foam::hierarchGeomDecomp::sortComponent(int, Foam::Field<double> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int> const&, unsigned char, int, Foam::List<int>&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so" [3] #4 Foam::hierarchGeomDecomp::sortComponent(int, Foam::Field<double> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int> const&, unsigned char, int, Foam::List<int>&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/l in "/home/reza/OpenFOA in "/home/reza/OpenFOAM/OpenFOM/OpenFAM-2.2.x/platformOAM-2.2.x/plas/linuxGcctforms/lDPOpt/lib/libdecoinuxGccDPOpmpositt/lib/libdecompionMethods.so"ositi onMethods[3] #5 .so" Foam::hierarchGeomDecomp::sortComponent(int, Foam::Field<double> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int> const&, unsigned char, int, Foam::List<int>&)[0] #5 Foam::hierarchGeomDecomp::sortComponent(int, Foam::Field<double> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int> const&, unsigned char, int, Foam::List<int>&)ib/libdecompositionMethods.so" [1] #5 Foam::hierarchGeomDecomp::sortComponent(int, Foam::Field<double> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int> const&, unsigned char, int, Foam::List<int>&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so" [2] #5 Foam::hierarchGeomDecomp::sortComponent(int, Foam::Field<double> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int> const&, unsigned char, int, Foam::List<int>&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so" [3] #6 Foam::hierarchGeomDecomp::sortComponent(int, Foam::Field<double> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int> const&, unsigned char, int, Foam::List<int>&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so" [1] #6 Foam::hierarchGeomDecomp::sortComponent(int, Foam::Field<double> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int> const&, unsigned char, int, Foam::List<int>&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so" [2] #6 Foam::hierarchGeomDecomp::sortComponent(int, Foam::Field<double> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int> const&, unsigned char, int, Foam::List<int>&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so" [0] #6 Foam::hierarchGeomDecomp::sortComponent(int, Foam::Field<double> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int> const&, unsigned char, int, Foam::List<int>&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so" in "/home/r[3] #7 eza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOFoam::hierarchGeomDecomp::decompose(Foa m::Field<Foam::Vector<double> > const&, Foam::Field<double> const&)pt/lib/libdecompositionMethods.so" [2] #7 Foam::hierarchGeomDecomp::decompose(Foam::Field<Fo am::Vector<double> > const&, Foam::Field<double> const&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so" [1] #7 Foam::hierarchGeomDecomp::decompose(Foam::Field<Fo am::Vector<double> > const&, Foam::Field<double> const&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so" [0] #7 Foam::hierarchGeomDecomp::decompose(Foam::Field<Fo am::Vector<double> > const&, Foam::Field<double> const&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so" [2] #8 Foam::hierarchGeomDecomp::decompose(Foam:olyMesh const&, Foam::Field<Foam::Vector<double> > const&, Foam::Field<double> const&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so" [0] #8 Foam::hierarchGeomDecomp::decompose(Foam:olyMesh const&, Foam::Field<Foam::Vector<double> > const&, Foam::Field<double> const&) in "/home/reza/OpenFOAM/OpenFOAM-2 in "/home/re.2.x/platforms/linuxGccDPOpt/libza/OpenFOAM/OpenFOAM-2./libdecompositionMethods.s2.x/platforms/linuxo" [3] #8 GccDPOpt/lib/libdecFoam::hierarchGeomDecomp::decompose(Foam:o lyMesh const&, Foam::Field<Foam::Vector<double> > const&, Foam::Field<double> const&)ompositionMethods.so" [1] #8 Foam::hierarchGeomDecomp::decompose(Foam:olyMesh const&, Foam::Field<Foam::Vector<double> > const&, Foam::Field<double> const&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so" [0] #9 Foam::meshRefinement::balance(bool, bool, Foam::Field<double> const&, Foam::decompositionMethod&, Foam::fvMeshDistribute&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so" [2] #9 Foam::meshRefinement::balance(bool, bool, Foam::Field<double> const&, Foam::decompositionMethod&, Foam::fvMeshDistribute&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so" [3] #9 Foam::meshRefinement::balance(bool, bool, Foam::Field<double> const&, Foam::decompositionMethod&, Foam::fvMeshDistribute&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so" [1] #9 Foam::meshRefinement::balance(bool, bool, Foam::Field<double> const&, Foam::decompositionMethod&, Foam::fvMeshDistribute&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libautoMesh.so" [2] #10 Foam::autoRefineDriver::doRefine(Foam::dictionary const&, Foam::refinementParameters const&, bool, Foam::dictionary const&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libautoMesh.so" [3] #10 Foam::autoRefineDriver::doRefine(Foam::dictionary const&, Foam::refinementParameters const&, bool, Foam::dictionary const&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libautoMesh.so" [0] #10 Foam::autoRefineDriver::doRefine(Foam::dictionary const&, Foam::refinementParameters const&, bool, Foam::dictionary const&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libautoMesh.so" [1] #10 Foam::autoRefineDriver::doRefine(Foam::dictionary const&, Foam::refinementParameters const&, bool, Foam::dictionary const&) in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libautoMesh.so" [0] #11 in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libautoMesh.so" [2] #11 in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libautoMesh.so" [3] #11 in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libautoMesh.so" [1] #11 [2] in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/bin/snappyHexMesh" [2] #12 __libc_start_main[0] in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/bin/snappyHexMesh" [0] #12 __libc_start_main[3] in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/bin/snappyHexMesh" [3] #12 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" [2] #13 in "/lib/i386-linux-gnu/libc.so.6" [0] #13 in "/lib/i386-linux-gnu/libc.so.6" [3] #13 [1] in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/bin/snappyHexMesh" [1] #12 __libc_start_main[2] in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/bin/snappyHexMesh" [ubuntu:09328] *** Process received signal *** [ubuntu:09328] Signal: Floating point exception (8) [ubuntu:09328] Signal code: (-6) [ubuntu:09328] Failing at address: 0x2470 [ubuntu:09328] [ 0] [0xb773340c] [ubuntu:09328] [ 1] [0xb7733424] [ubuntu:09328] [ 2] /lib/i386-linux-gnu/libc.so.6(gsignal+0x4f) [0xb54281df] [ubuntu:09328] [ 3] /home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libOpenFOAM.so(_ZN4Foam6sigFpe10sigHandlerEi+0x60) [0xb5c04320] [ubuntu:09328] [ 4] [0xb7733400] [ubuntu:09328] [ 5] /home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so(_ZN4Foam18hierarchGeomD ecomp28calculateSortedWeightedSizesERKNS_4ListIiEE S4_RKNS_5FieldIdEEiRS6_+0x160) [0xb65d2220] [ubuntu:09328] [ 6] /home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so(_ZN4Foam18hierarchGeomD ecomp13sortComponentEiRKNS_5FieldIdEERKNS1_INS_6Ve ctorIdEEEERKNS_4ListIiEEhiRSB_+0x20d) [0xb65d473d] [ubuntu:09328] [ 7] /home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so(_ZN4Foam18hierarchGeomD ecomp13sortComponentEiRKNS_5FieldIdEERKNS1_INS_6Ve ctorIdEEEERKNS_4ListIiEEhiRSB_+0x8aa) [0xb65d4dda] [ubuntu:09328] [ 8] /home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so(_ZN4Foam18hierarchGeomD ecomp13sortComponentEiRKNS_5FieldIdEERKNS1_INS_6Ve ctorIdEEEERKNS_4ListIiEEhiRSB_+0x8aa) [0xb65d4dda] [ubuntu:09328] [ 9] /home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so(_ZN4Foam18hierarchGeomD ecomp9decomposeERKNS_5FieldINS_6VectorIdEEEERKNS1_ IdEE+0x23c) [0xb65d552c] [ubuntu:09328] [10] /home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so(_ZN4Foam18hierarchGeomD ecomp9decomposeERKNS_8polyMeshERKNS_5FieldINS_6Vec torIdEEEERKNS4_IdEE+0x28) [0xb65d5838] [ubuntu:09328] [11] /home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libautoMesh.so(_ZN4Foam14meshRefinement7balanceEbb RKNS_5FieldIdEERNS_19decompositionMethodERNS_16fvM eshDistributeE+0x45a) [0xb5e125ca] [ubuntu:09328] [12] /home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libautoMesh.so(_ZN4Foam16autoRefineDriver8doRefine ERKNS_10dictionaryERKNS_20refinementParametersEbS3 _+0x24d) [0xb5de510d] [ubuntu:09328] [13] snappyHexMesh() [0x8050676] [ubuntu:09328] [14] /lib/i386-linux-gnu/libc.so.6(__libc_start_main+0xf3) [0xb54134d3] [ubuntu:09328] [15] snappyHexMesh() [0x8050d61] [ubuntu:09328] *** End of error message *** in "/lib/i386-linux-gnu/libc.so.6" [1] #13 [3] in "/home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/bin/snappyHexMesh" [ubuntu:09329] *** Process received signal *** [ubuntu:09329] Signal: Floating point exception (8) [ubuntu:09329] Signal code: (-6) [ubuntu:09329] Failing at address: 0x2471 [ubuntu:09329] [ 0] [0xb77a240c] [ubuntu:09329] [ 1] [0xb77a2424] [ubuntu:09329] [ 2] /lib/i386-linux-gnu/libc.so.6(gsignal+0x4f) [0xb54971df] [ubuntu:09329] [ 3] /home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libOpenFOAM.so(_ZN4Foam6sigFpe10sigHandlerEi+0x60) [0xb5c73320] [ubuntu:09329] [ 4] [0xb77a2400] [ubuntu:09329] [ 5] /home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so(_ZN4Foam18hierarchGeomD ecomp28calculateSortedWeightedSizesERKNS_4ListIiEE S4_RKNS_5FieldIdEEiRS6_+0x160) [0xb6641220] [ubuntu:09329] [ 6] /home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so(_ZN4Foam18hierarchGeomD ecomp13sortComponentEiRKNS_5FieldIdEERKNS1_INS_6Ve ctorIdEEEERKNS_4ListIiEEhiRSB_+0x20d) [0xb664373d] [ubuntu:09329] [ 7] /home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so(_ZN4Foam18hierarchGeomD ecomp13sortComponentEiRKNS_5FieldIdEERKNS1_INS_6Ve ctorIdEEEERKNS_4ListIiEEhiRSB_+0x8aa) [0xb6643dda] [ubuntu:09329] [ 8] /home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so(_ZN4Foam18hierarchGeomD ecomp13sortComponentEiRKNS_5FieldIdEERKNS1_INS_6Ve ctorIdEEEERKNS_4ListIiEEhiRSB_+0x8aa) [0xb6643dda] [ubuntu:09329] [ 9] /home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so(_ZN4Foam18hierarchGeomD ecomp9decomposeERKNS_5FieldINS_6VectorIdEEEERKNS1_ IdEE+0x23c) [0xb664452c] [ubuntu:09329] [10] /home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdecompositionMethods.so(_ZN4Foam18hierarchGeomD ecomp9decomposeERKNS_8polyMeshERKNS_5FieldINS_6Vec torIdEEEERKNS4_IdEE+0x28) [0xb6644838] [ubuntu:09329] [11] /home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libautoMesh.so(_ZN4Foam14meshRefinement7balanceEbb RKNS_5FieldIdEERNS_19decompositionMethodERNS_16fvM eshDistributeE+0x45a) [0xb5e815ca] [ubuntu:09329] [12] /home/reza/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libautoMesh.so(_ZN4Foam16autoRefineDriver8doRefine ERKNS_10dictionaryERKNS_20refinementParametersEbS3 _+0x24d) [0xb5e5410d] [ubuntu:09329] [13] snappyHexMesh() [0x8050676] [ubuntu:09329] [14] /lib/i386-linux-gnu/libc.so.6(__libc_start_main+0xf3) [0xb54824d3] [ubuntu:09329] [15] snappyHexMesh() [0x8050d61] [ubuntu:09329] *** End of error message *** -------------------------------------------------------------------------- mpirun noticed that process rank 2 with PID 9328 on node ubuntu exited on signal 8 (Floating point exception). |
October 22, 2013, 09:08 |
Artur
Rep Power: 19 |
Have you tried running surfaceCheck on your object? Are you sure the inside point is not on an edge or a face of either the blockMesh or the body?
October 23, 2013, 04:41 |
Hi
Reza
Thank you, I tried surface check and it seems that the problem was selected point.
Regards |
point, snappyhexmesh |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 06:01 |
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing | peterhess | OpenFOAM Meshing & Mesh Conversion | 2 | January 3, 2018 02:54 |
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. | jasv | OpenFOAM Meshing & Mesh Conversion | 4 | May 10, 2016 02:55 |
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? | klausb | OpenFOAM Meshing & Mesh Conversion | 1 | March 7, 2015 11:55 |
[snappyHexMesh] stitchMesh and snappyHexMesh | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 0 | December 23, 2009 02:09 |
