[snappyHexMesh] Setting up a periodic heat transfer case with cooling rips
Old   October 23, 2013, 09:12
Default Setting up a periodic heat transfer case with cooling rips
phil
gelbebanane is on a distinguished road
Hey Guys,
I'm setting up my first testcase. Like the title says it is a periodic heat transfer case. Periodic means in my case its an infinite loop of the same geometry bodies.
blockMesh is already running but i don't know if i have the right snappyHexMesh setup. I have added some pictures to illustrate my case.
I worked my way through the "motorBike" sHMDict and changed the necessary values.
So here is my .stl sHMDict and blockMeshDict file so you can try it by yourself. If you also need anything else let me know!
blockMeshDict.txt
snappyHexMeshDict.txt
kanal.stl.txt just rename it to kanal.stl otherwise no upload possible
gelbebanane is offline   Reply With Quote
Old   October 24, 2013, 04:13
phil
Ok so now I'm 1 step further. sHM is running through (10 minutes ), think my refinement levels are too small.
I've created *.eMesh with surfaceFeatureExtract.
Nevertheless i have still some snapping problems at the edges, see attached picture.
Has someone suggestion what i could change?
By the way surfaceCheck says my *.stl is not closed, does this matter for my case or do i have to close it and if yes how?
I have to apologize for my bad english, i'm a bit out of practice.
Greetings
Conjugated heat transfer (CHT): Solid not cooling down pythag0ra5 CFX 3 August 6, 2017 18:54
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Conjugate heat transfer with periodic boundaries Suresh FLUENT 0 February 23, 2009 09:51
