[snappyHexMesh] How to create an open cylinder using FreeCAD
Old   February 12, 2014, 05:05
Question How to create an open cylinder using FreeCAD
ttttoor
meng9019 is on a distinguished road
Dear all,
I am trying to use snappyHexMesh according to the cylinder case tutorial: https://sites.google.com/site/snappy.../cylinder-case
I can use FreeCAD to create a close cylinder and export it into .stl file format. But how can I get .stl file of an open cylinder.
Thank you in advance.
meng9019 is offline   Reply With Quote
Old   February 13, 2014, 09:11
Paulo Vatavuk
vatavuk is on a distinguished road
Did you notice that there is a link in the page, where you can download all necessary files, including the stl files?
Best Regards,
Paulo
vatavuk is offline   Reply With Quote
Old   February 14, 2014, 09:19
ttttoor
Hi, Paulo,
Thank you.
I have found a way to create the stl file for an open cylinder.
I create a cylinder geometry using FreeCAD and save it as an stl file.
Then I open the stl file and delete the faces normal to z-direction by hand.
But I want to know whether it is possible to get and save an open cylinder directly using FreeCAD.
Originally Posted by vatavuk View Post
Best Regards,
Paulo
Old   March 14, 2014, 08:24
cutter is on a distinguished road
I don't know about FreeCAD, but this can be done directly in Salome (explode to faces, select side face, export to STL).
STL surfaces need to be closed for meshing though. So what are you really trying to achieve?!
Cutter
cutter is offline   Reply With Quote
freecad, open cylinder, stl file
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 16:18
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 06:47
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 17:34
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
