April 4, 2014, 04:20 |
SHM does not cut out STL
Youngkook Kim
Rep Power: 12 |
Hi formers,
I am trying to run a ship case in open sea and generating mesh from STL surface. Everything was okay for the very coarse mesh but not the fine mesh. Just as the attached(still not very fine), SnappyHexMesh does not cut out the STL surface. Surfacecheck.exe says the surface is not closed and give out more than 70 *.obj. I tried Blender but my STL has so many elements and cannot really find what the problem is. Anyone has good idea to settle this problem? Thanks, Youngkook |
June 4, 2014, 06:21 |
SnappyHexMesh
Nithish
Rep Power: 12 |
Can you post your case
August 3, 2014, 02:51 |
Youngkook Kim
Rep Power: 12 |
The problem persisted in OF 2.1.1 but not in 2.3.0.
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 06:01 |
[snappyHexMesh] Checkinf if SHM stl files are watertight | fracasce | OpenFOAM Meshing & Mesh Conversion | 2 | April 25, 2017 06:50 |
[snappyHexMesh] SHM does not follow STL geometry well | Illmatic | OpenFOAM Meshing & Mesh Conversion | 7 | July 23, 2016 11:07 |
[snappyHexMesh] sHM with cyclic patch on stl geometry | johannesk | OpenFOAM Meshing & Mesh Conversion | 2 | August 21, 2009 09:08 |
