[Other] Mesh Conversion to Openfoam problem
Old   June 13, 2014, 09:28
Default Mesh Conversion to Openfoam problem
hassan
Ahadi is on a distinguished road
Hello everybody, sorry that my first thread is a problem! I was trying to convert a simple geometry (T-shape pipe, two inlet and one outlet) mesh from Salome 7.3.0 to openfoam 2.3.0 on Ubuntu 14.04 and I ran into this error. This is my first time using both softwares so I am suspecting installation issues. I have been looking in Google using different keywards relating to the error but no luck. One more info could be relevant is that I am running this on mac 64 bit processor. I used ideasunvtofoam command and it gave me this message:
Create time
Processing tag:164
Starting reading units at line 3.
l:1
units:" SI: Meter (newton)"
unitType:2
Unit factors:
Length scale : 1
Force scale : 1
Temperature scale : 1
Temperature offset : 273.15
Processing tag:2420
Skipping tag 2420 on line 9
Skipping section at line 9.
Processing tag:2411
Starting reading points at line 20.
Read 5642 points.
Processing tag:2412
Starting reading cells at line 11307.
First occurrence of element type 11 for cell 1 at line 11308
First occurrence of element type 44 for cell 766 at line 13603
First occurrence of element type 41 for cell 2326 at line 16723
Read 0 cells and 5655 boundary faces.
Processing tag:2467
Starting reading patches at line 24915.
For group 6 named inlet trying to read 1125 patch face indices.
For group 7 named inlet trying to read 1125 patch face indices.
For group 8 named outlet trying to read 1125 patch face indices.
For group 9 named wall trying to read 2280 patch face indices.
Sorting boundary faces according to group (patch)
0: inlet is #0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigSegv::sigHandler(int) at ??:?
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
at ??:?
#4 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
at ??:?
Segmentation fault (core dumped)
My question is just where do you think the poblem lies exactly. When I ran tutorials of Openfoam I did not encounter any problem. Yet when I tried to convert the mesh from Salome I get this.
Thank you in Advance
Ahadi is offline   Reply With Quote
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
[Commercial meshers] SolidWorks to ANSYS to OpenFoam mesh conversion failed nuclear_swapnil OpenFOAM Meshing & Mesh Conversion 1 October 11, 2017 00:38
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[Commercial meshers] mesh conversion from ansys mesher to openfoam Dusan1224 OpenFOAM Meshing & Mesh Conversion 2 November 5, 2015 03:41
Moving mesh problem OpenFoam 141 kassiotis OpenFOAM Running, Solving & CFD 30 April 14, 2015 23:10
