February 18, 2018, 08:49 |
Moving Mesh in compressible flow
harshawardhank
Rep Power: 13 |
Hello friends,
I want to implement dynamic meshing in Compressible flow in OpenFOAM how to do this??? regards Harshawardhan |
February 26, 2018, 17:41 |
Rep Power: 14 |
There are a few compressible solvers that already have dynamic meshing, e.g. sonicDyMFoam, rhoPimpleDyMFoam.
Caelan |
February 26, 2018, 20:41 |
harshawardhank
Rep Power: 13 |
February 26, 2018, 20:50 |
Rep Power: 14 |
March 16, 2018, 07:12 |
#5 | |
harshawardhank
Rep Power: 13 |
velocityComponentLaplacianCoeffs |
April 29, 2018, 04:28 |
Elham
Rep Power: 16 |
I have developed my own code which has dynamic mesh feature. But whenever I run it I have the following error in parallel run: Forcing regeneration of surface interface [3] [3] [3] --> FOAM FATAL ERROR: [3] index 1250 out of range 0 ... 1249 [3] [3] From function UList<T>::checkIndex(const label) [3] in file /home/elham/OpenFOAM/OpenFOAM-2.3.1/src/OpenFOAM/lnInclude/UListI.H at line 109. Any comment is appreciated. Regards, Elham |
April 30, 2018, 09:38 |
Rep Power: 14 |
Without seeing your code it's hard to help, but the error message suggests an indexing problem.
Caelan |
May 4, 2018, 03:34 |
#8 | |
Elham
Rep Power: 16 |
I am running the solver with 3D mesh without any problem. Probably there is a problem with 2D dynamic mesh that I don't understand. Regards, Elham |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
A compressible solver with moving mesh and heat flux? | massive_turbulence | OpenFOAM Pre-Processing | 2 | August 31, 2021 10:35 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? | karkar | OpenFOAM Meshing & Mesh Conversion | 0 | July 4, 2012 06:54 |
Moving Mesh Velocity Issue: Mesh velocity does not equal displacement | Doginal | CFX | 2 | September 8, 2011 12:02 |
