October 6, 2014, 04:40 |
snappy snaps to bad surface
Petr Furmanek
Rep Power: 14 |
Hi all!
I have the following problem with snappyHexMesh: I have to mesh an object with a thin surface. The geometry is closed (and supplied in stl format). Snappy however breaks through the surface it should be snapping to and snaps to the underlying surfaces - please see the pictures. I can help it by setting tolerance to 1.0 but then other parts of the mesh are distorted. I'm using OF2.3.x, where this shouldn't appear at all (due to the new feature detectNearSurfacesSnap). Any idea what to change in the settings? |
October 11, 2014, 12:37 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Petr,
A few questions:
Bruno
October 13, 2014, 05:14 |
Petr Furmanek
Rep Power: 14 |
Hello Bruno,
thanks a lot for your reply. The answers to your questions are: 1) Yes I am. 2) In total 13 stl files with many closed surfaces (~ 72). 3) There is quite a lot of cells in the refined mesh. But as you can see from the pictures it's less than in the original stl file. I'll try to run all the stages separately and let you know. Best regards, Petr. |
October 18, 2014, 14:59 |
Bruno Santos
Rep Power: 128 |
Quick hint: As with most things related to OpenFOAM, you should always start investigating functionalities in OpenFOAM by starting with one or more simpler cases, so that you can isolate one problem at a time
If you read this wiki page: http://openfoamwiki.net/index.php/SnappyHexMesh - you should get that exact feeling as well |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[snappyHexMesh] Snappy Hex Mesh - issue with smoothness of the model edges | olek.warc | OpenFOAM Meshing & Mesh Conversion | 1 | August 31, 2018 11:31 |
[ICEM] bad elements on symmetry surface | Pawel Zdunek | ANSYS Meshing & Geometry | 3 | June 16, 2017 20:05 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
