[snappyHexMesh] snappyHexMesh on a multiple region blockMesh
Old   November 17, 2014, 15:54
Default snappyHexMesh on a multiple region blockMesh
Bruno Blais
blais.bruno is on a distinguished road
Hello everyone.
To quickly mesh an impeller rotating in a stirred tank, I would like to use snappyHexMesh on top of a structure blockMesh which encompasses the AMI interface.
I Have already made the structured blockMesh that has the AMI patches and a rotating cylinder of fluid in the middle. Everything is fine.
However, when comes to time to use snappyHexMesh, if the point "inside" that I specify is within the rotor region, the entire stator region. It seems that snappyHexMesh only detects the region in which the locationInMesh point is in.
Do any of you know a work around to this issue? (namely keeping the two regions...)
Cheers,
Bruno
blais.bruno is offline   Reply With Quote
Old   February 17, 2015, 05:40
M. Montero
be_inspired is on a distinguished road
http://www.cfd-online.com/Forums/ope...tml#post532134
I think your problem is quite similar to mine in some points.
Now I am dealing with rotorDiskSource but I have obtained a valid wind turbine mesh with the blades meshed and so. You will need a cylinder STL geometry to define that all the cells inside that cylinder will be a new cellZone.
Inside surfaceRefinement:
rotating
level (1 2);
cellZone rotating;
faceZone rotating;
cellZoneInside insidePoint;
insidePoint (0 0.1 0.5);
be_inspired is offline   Reply With Quote
Problem simulating the temperature rise in a composite material (chtMultiRegionFoam) Adam_K OpenFOAM Running, Solving & CFD 2 March 27, 2019 06:51
[snappyHexMesh] can snappy run with multiple block in blockMesh BakedAlmonds OpenFOAM Meshing & Mesh Conversion 9 November 29, 2018 06:30
[blockMesh] 3D blockMesh for multiple material rectangular blocks one above another Sargam05 OpenFOAM Meshing & Mesh Conversion 0 September 22, 2012 21:46
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
