[mesh manipulation] topoSetDict. rotate box
Like Tree3Likes
  • 1 Post By alexeym
  • 2 Post By derekm
Old   February 23, 2015, 04:58
Default topoSetDict. rotate box
Svensen is on a distinguished road
Is there a way to rotate box defined in the topoSetDict ?
I want to define a set of faces with a boxside not parallel to any of x, y, z axis
Svensen is offline   Reply With Quote
Old   February 23, 2015, 05:07
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Yes, there is, it is called rotatedBoxToCell, here's an example
        name c0;
        type cellSet;
        action new;
        source rotatedBoxToCell;
        sourceInfo
            origin (-0.0312     -0.0202 -1);
            i (0.009238795325112868 -0.003826834323650898 0);
            j (0.022961005941905387 0.0554327719506772 0);
            k (0 0 2);
You can find another example in topoSetDict in topoSet utility source folder. Also inside H and C files in $FOAM_SRC/meshTools/sets/cellSources/rotatedBoxToCell.
kokab likes this.
alexeym is offline   Reply With Quote
Old   February 23, 2015, 07:03
Can you explain the meaning of each parameter ?
Because all I want is to specify the center point, the length, axis of rotation and the angle of rotation.
But I don't understand how using the rotatedBoxToCell specify the rotated box in this way...
Old   February 23, 2015, 07:12
Alexey Matveichev
if you go to $FOAM_SRC/meshTools/sets/cellSources/rotatedBoxToCell and open rotatedBoxToCell.C file, you will see these lines:
    pointField boxPoints(8);
    boxPoints[0] = origin_;
    boxPoints[1] = origin_ + i_;
    boxPoints[2] = origin_ + i_ + j_;
    boxPoints[3] = origin_ + j_;
    boxPoints[4] = origin_ + k_;
    boxPoints[5] = origin_ + k_ + i_;
    boxPoints[6] = origin_ + k_ + i_ + j_;
    boxPoints[7] = origin_ + k_ + j_;
This is how coordinates of the corners of the box are calculated.
Well, you can implement your own anotherRotatedBoxToCell to take described parameters.
Old   March 6, 2015, 16:22
I've tried to use the rotatedBoxToCell with defining the origin and i,j,k components, but I've got strange results... topoSet says that "0 cells are selected"... I've attached the Image with my geometry and original point (shown as green) and i,j,k points.
The coordinates of origin point were used "as is". i,j,k components were defined with subtraction of components. For example for j component j=(j_x - origin_x; j_y - origin_y; j_z - origin_z). Mathematically it is OK, because according to the source code of the rotatedBoxToCell there values of components will be added with the values of the origin point (addition of vectors). But why topoSet gives me "0 cells are selected"... ?
Maybe someone had this problem before ?...
Old   March 6, 2015, 16:48
Derek Mitchell
derekm is on a distinguished road
yes, i,j,k have to be correct handed or it gives you zero
jherb and zfaraday like this.
A CHEERING BAND OF FRIENDLY ELVES CARRY THE CONQUERING ADVENTURER OFF INTO THE SUNSET
derekm is offline   Reply With Quote
Old   March 7, 2015, 03:03
Alexey Matveichev
@Svensen, if you provide more details (real values of i, j, k and location of (0, 0, 0) point on the picture) the answer could be more precise. Usually topoSet selects 0 cells if volume of box is negative (or maybe you just miss the scale of the mesh?).
Old   March 7, 2015, 04:18
I've already founded the solution for this problem: I redefined the vectors to form right-hand system of vectors.
Old   March 13, 2015, 15:38
Alex
zfaraday will become famous soon enough
Thanks Derek for your wise words! I've been struggling all the afternoon trying to select a set of cells with a rotated box and I had no clue what was the reason why it wasn't selecting anything. Now I finally could make it work as I wanted!
Cheers,
Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
The sampled data is not restricted to the defined zone in topoSetDict jiaodanuma OpenFOAM Post-Processing 1 August 14, 2018 07:25
Initial values and boundary condition for LES simulation of a box SaddamH OpenFOAM Running, Solving & CFD 1 July 31, 2018 02:21
I get different results when I scale the 'falling box' tutorial Hossein1 FLUENT 7 August 19, 2017 02:52
[DesignModeler] simply model, empty box conquer ANSYS Meshing & Geometry 0 March 28, 2014 18:26
Immersol Simulation of a Heated Box Dong Phoenics 0 March 2, 2006 21:20
