[snappyHexMesh] snappyHexMesh meshed inside an outside of stl
Old   March 22, 2015, 09:38
Default snappyHexMesh meshed inside an outside of stl
BastiL
bastil is on a distinguished road
Hello all,
I have a complex stl-geometry which I want to mesh using sHM. The geometry is captured fine. However, it meshes not just inside the geometry (as desired) but also parts of the outside. I guess there is at least one hole in the geometry... The surface extracted after the castellated phase looks correct. What ways are there to find the connection paths between inside and outside? Maybe giving two point one inside and one outside and find the path between them? Thanks.
bastil is offline   Reply With Quote
Old   March 24, 2015, 04:09
Jens Höpken
jhoepken is on a distinguished road
Send a message via Skype™ to jhoepken
I think you guessed correctly: the geometry is most likely to have a hole. Run surfaceCheck on the stl file and check. If no hole is detected, try to move locationInMesh to a different position, not on a geometry face or cell face.
Blog: sourceflux.de/blog
"The OpenFOAM Technology Primer": sourceflux.de/book
Twitter: @sourceflux_de
Interested in courses on OpenFOAM?
jhoepken is offline   Reply With Quote
Old   May 6, 2016, 12:00
thomas
thomas. is on a distinguished road
Hello all,
I actually need to mesh both inside and outside parts of an .stl-file. How can I do it? I want to use the internal mesh as an volumetric heat source, so that the fluid that goes through those cells gets heated (buoyancy case). I want to try it this way because I will export the mesh to Fluent and then set the internal mesh as an "heat source cell zone".
Thank you very much in advance.
thomas. is offline   Reply With Quote
Old   May 6, 2016, 12:12
thomas
I added three images in order to visualize what I mean. In the "inside" picture you see a long thin cylinder. That's supposed to be the volumetric heat source. The fluid is supposed to go through it in order to get warmer.
Old   May 7, 2016, 12:11
Antimony is on a distinguished road
Refer to slide 31 in this presentation:
http://openfoamwiki.net/images/f/f0/...SlidesOFW7.pdf
By setting cellZoneInside to inside, you will be meshing the interior of the STL. Furthermore, by specifying names of faceZone and cellZone (which you can convert to cellSet via topoSet), you can specify the region where your heat source should act.
Hope this helps.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   May 7, 2016, 16:12
thomas
Thank you very much! I will give it a try.
[snappyHexMesh] snappyHexMesh not deleting the inside cells Bdew8556 OpenFOAM Meshing & Mesh Conversion 9 May 14, 2019 10:53
[snappyHexMesh] Creating STL files with regions for snappyHexMesh nusivares OpenFOAM Meshing & Mesh Conversion 4 August 7, 2018 20:09
[snappyHexMesh] SHM error: inside mesh not possible Naresh yathuru OpenFOAM Meshing & Mesh Conversion 1 January 10, 2017 23:58
Generating a proper STL mesh for snappyHexMesh riccardomaione OpenFOAM Pre-Processing 2 August 25, 2015 02:17
[snappyHexMesh] STL format in SnappyHexMesh samiraamiri OpenFOAM Meshing & Mesh Conversion 5 July 20, 2015 08:19
