January 27, 2010, 05:32 |
someLine.eMesh format file
elisenda lopez
Dear all,
I am trying to mesh an stl geometry with snappyHexMesh. I can see that the feature lines (or edges) I have in the geometry are omitted. The mesh don't follows the lines. I would like to use the someLine.eMesh file but I don't know their format and I don't know where I have to place it into the structure directories. I don't know if this is a good way but I have not other ideas. 1) Can anybody help me how to use and how to generate the someLine.eMesh file? 2) Have anybody any other ideas? Thanks in advance, Elisenda |
January 27, 2010, 09:57 |
Wolfram Kretzschmar
Hi Elisenda,
Is that what you mean by "feature lines/edges are omitted"? http://www.cfd-online.com/Forums/ope...try-edges.html There are some other threads about that in the forum, but I (not experienced at all!) think, there's no solution to that problem at the moment. I don't know, whether the someLine.eMesh approach is adequate for this kind of problem, but would be interested too. Anyway I didn't read anything about that yet and came across these settings just today... Cheers Wolle |
January 28, 2010, 02:52 |
elisenda lopez
Hello Wolle,
This is exactly what I mean. I think the eMesh file can help me. I am not sure but I would like to try. The problem is that I don't know their format. Has anybody idea about the eMesh format? |
January 28, 2010, 03:25 |
Norman Del Puppo
Hi!
Look at the iglooWithFridges/constant/triSurface/fridgeA.eMesh file: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: http://www.openfoam.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; root ".."; case "cavity"; instance ""constant""; local "polyMesh"; class featureEdgeMesh; object points; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Points ( (1.99 1.99 0.01) //0 (3.01 1.99 0.01) //1 (3.01 3.01 0.01) //2 (1.99 3.01 0.01) //3 (1.99 1.99 2.01) //4 (3.01 1.99 2.01) //5 (3.01 3.01 2.01) //6 (1.99 3.01 2.01) //7 ) // Edges ( (0 1) (1 2) (2 3) (3 0) (4 5) (5 6) (6 7) (7 4) (0 4) (1 5) (2 6) (3 7) ) // ************************************************** *********************** // Regards Norman |
January 28, 2010, 04:30 |
elisenda lopez
Hi Norman,
Thank you for your very quick answer. I will try with this format. I will say you if the mesh follows the edges. Thanks and regards, Elisenda |
January 28, 2010, 05:26 |
elisenda lopez
Hi Norman,
I used this format and the snappyHexMesh runs well. The problem is that the mesh don't follows the edges. I don't know what I can do. Any suggestions? Elisenda |
January 28, 2010, 05:29 |
#7 | |
Norman Del Puppo
I tried that solution last april and it didn't improve my case so much.. maybe the new snappyHexMesh version works better using these feature lines but I think you'll only get a refinement around your feature lines because the edge capturing is not already implemented in snappyHexMesh :-( Anyway let me know! Regards Norman |
January 28, 2010, 07:09 |
elisenda lopez
Hi Norman,
I use "level 10" on the edges.eMesh file: features ( { file "edges.eMesh"; level 10; } ); and the mesh is refined near the edges. I have a lot of elements. It is not bad, but it would be better follows the edges but without increase the number of elements. It is a pity. Elisenda |
January 28, 2010, 07:41 |
Norman Del Puppo
Hi Elisenda,
I agree but this is the only way to get a grid that follow in some way your edges because at this moment the edge capturing is not implemented in snappyHexMesh. Norman |
March 3, 2010, 03:33 |
stephane sanchi
Rep Power: 18 |
Hi Elisenda,
Have you find a way or a 'best strategy' to improve your mesh quality near the edges ? Best regards, Stephane |
March 19, 2010, 05:04 |
#11 |
elisenda lopez
Stephane,
This is the only way I have found. I don't know if there is another one. |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
