[snappyHexMesh] layer minthickness
Old   April 20, 2010, 06:14
Default layer minthickness
Marine
marine is on a distinguished road
hello!
I'm trying to make a boundary layer around a hull.
The parts 1 and 2 of snappy work well but I have some problems with part 3. When the snappy generate a boundary layer it's not for the entire hull but for some parts of it, which are not every time the sames.
Does someone know how to choose the parameter "minthickness" ? does it define the min thickness of the entire layer or of the first cell, or something else?
thank you!!
Marine
marine is offline   Reply With Quote
Old   April 22, 2010, 10:03
Moritz Wied
Mo-ITB is on a distinguished road
Hi Marine,
minThickness defines the thickness of one layer relative to the cell outside the layer.
you may just make it smaller. your problem could also be solved by decreasing the featureAngle in addLayerControls.
Cheers,
Moritz
Mo-ITB is offline   Reply With Quote
addlayercontrols, boundary layer thickness, minthickness
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 08:26
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner panpanzhong OpenFOAM Meshing & Mesh Conversion 5 July 3, 2018 05:53
Prismatic boundary layer KateEisenhower enGrid 5 September 15, 2015 07:48
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 13:47
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
