[snappyHexMesh] refineWallLayer
Old   July 15, 2010, 09:10
Default refineWallLayer
stephane sanchi
openfoam_user is on a distinguished road
hello,
can someone give me an example how to use the refineWallLayer utility with snappyHexMesh ?
Regards,
Stephane
openfoam_user is offline   Reply With Quote
Old   July 16, 2010, 10:35
stephane sanchi
With snappyHexMesh just create 1 'big' layer. Then use several times the refineWallLayer utility to refine.
if your solid is composed of 3 surfaces called : head, body and back
refineWallLayer -overwrite head 0.3
refineWallLayer -overwrite body 0.3
refineWallLayer -overwrite back 0.3
At the end check your final mesh with:
checkMesh -latestTime
Stephane
Old   July 29, 2011, 09:47
Stefan
SD@TUB is on a distinguished road
Hi Stephane,
I agree with you, in cases where addLayers functionality with snappyHexMesh fails to add several layers.
Do you have a work around to refine the wall layers from different patches at once?
I tried
refineWallLayer [OPTIONS] 'patch1 patch2,...' <edgeWeight>
refineWallLayer [OPTIONS] '(patch1 patch2,...)' <edgeWeight>
refineWallLayer [OPTIONS] '(patch1,patch2,...)' <edgeWeight>
refineWallLayer [OPTIONS] ':patch1,patch2,...:' <edgeWeight>
w/o success! I guess that there is no behavior like a <wordList> implemented,
so right now i have to use a shell script...
May you or someone else could give me an advice? Thanks!
/Stefan
SD@TUB is offline   Reply With Quote
Old   October 11, 2012, 16:22
Default write last step only
ic3wall is on a distinguished road
I know it's an old thread, but do you know a way to write only the last mesh of refineWallLayer when it is used in a shell script ?
Writing the mesh at each iteration is very time consuming.
ic3wall is offline   Reply With Quote
Old   October 12, 2012, 09:49
Stefan
It should be working if you set 'startFrom latestTime;' in <constant/controlDict>!
/Stefan
Old   October 12, 2012, 09:52
I tried that, but it still writes the new mesh each time refineWallLayer is executed.
Old   October 16, 2012, 09:32
Stefan
I can't understand it. It should be working. There is a '-overwrite' flag that overwrite the mesh of last time step. If this flag isn't used, the application write out the mesh to the new time step.
What version do you use? What is your script look like?
/Stefan
Old   October 16, 2012, 10:29
The overwrite flag, if I understand it correctly, simply overwrites the time in which the mesh is currently located. For example, if you apply refineWallLayer (with the overwrite flag on) on a mesh in time 1, the new "refined" mesh will be written in time 1, deleting the old mesh. Without the overwrite flag, the new mesh will simply be written in time 2.
My script looks like that:
. $WM_PROJECT_DIR/bin/tools/RunFunctions
while [ condition]
do
stuff to calculate refineWallLayer inputs
runApplication refineWallLayer lowerWall $Ratio -overwrite
rm log.refineWallLayer
done
exit
With the above script, a new mesh is written each loop, which becomes a very long process when the application is run 100+ times..My guess is that modifications in refineWallLayer.C would be needed.
I use OF 1.7.1
Old   October 17, 2012, 11:30
Stefan
That's fully correct! After clearing this point, I am a little confused what you are really intend to do!? refineWallLayer need to handle the whole mesh despite 'just' splitting all cells near of your specified patch. If you want to speed up, use it in parallel (by runParallel in your script).
/Stefan
Old   October 17, 2012, 16:25
I know refineWallLayer deals with the hole mesh, but is there a way to tell the utility to keep the last iteration in memory instead of writing it and then reading it for the next iteration ?
i didn't think of running it in parallel ... but again decomposing and reconstructing the mesh at each iteration will be time consuming as well
Old   October 20, 2012, 12:59
Stefan
Now I get what you want. Yes, that should be done by rewriting refineWallLayer.C. I am not sure if writing memory to disk drive is the time consuming part!? Did you check this?
Another possibility might by using subSetMesh to write near wall layer to separate mesh, perform refining and stitch it with 'far field mesh' afterwards. Didn't try it yet.
/Stefan
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 11:04
[snappyHexMesh] refineWallLayer vs add layer Astan OpenFOAM Meshing & Mesh Conversion 0 March 18, 2019 12:03
refineWallLayer error after upgrading wildfire230 OpenFOAM Pre-Processing 2 October 27, 2017 15:21
refineWallLayer cellZone preservation workaround jameswilson620 OpenFOAM 0 May 10, 2016 10:56
[snappyHexMesh] snappyHexMesh and refineWallLayer Claudio OpenFOAM Meshing & Mesh Conversion 0 June 20, 2013 13:36
