[snappyHexMesh] Ship hull using snappyHexMesh |
August 27, 2010, 05:52 |
Emanuele
Rep Power: 17 |
Hi, i made a mesh around a ship hull using snappyHexMesh. The "checkMesh" returns me a warning on 2 non-orthogonal faces (with checkMesh on 1.6 i had no warning). I started the simulation but it fails with a Floating point exception error. Have you any idea??
This is the case http://ubuntuone.com/p/E1i/ Regards Emanuele |
hull, mesh, ship, snappyhexmesh |
[snappyHexMesh] SnappyHexMesh Ship Hull with Appendages Problem | bizzy | OpenFOAM Meshing & Mesh Conversion | 7 | December 14, 2017 16:22 |
Ship hull with appendage as seperate patch runs into error | manoj_nav | OpenFOAM Running, Solving & CFD | 1 | March 13, 2016 09:12 |
How to output the water resistance on a Ship hull | Sachin m | OpenFOAM Post-Processing | 1 | January 26, 2015 12:24 |
Free surface comes above the hull of the ship | Sachin m | OpenFOAM Pre-Processing | 0 | September 4, 2014 00:08 |
Error in meshing a Ship hull using snappyhexmesh | Sachin m | OpenFOAM Pre-Processing | 1 | August 27, 2014 23:27 |
