[blockMesh] Inconsistent number of faces |
June 5, 2006, 13:27 |
Giuseppe Noviello
Rep Power: 17 |
Hi to all
Which means this error of blockMesh? > FOAM FATAL ERROR : Inconsistent number of faces between block pair 2 and 4 From function blockMesh::blockMesh(IOdictionary& meshDescription) in file createMergeList.C at line 202. FOAM exiting Someone can help me? Thanks in advantage Giuseppe |
June 5, 2006, 13:29 |
It means you've got 2 blocks y
Hrvoje Jasak
Rep Power: 33 |
It means you've got 2 blocks you are trying to connect to each other in blockMesh but they haven't got the matching number of cells in this direction or that the scaling is different.
Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
July 17, 2012, 09:10 |
Trouble with blockMesh: inconsistent number of faces between block pairs 0 and 1
Deepak Cheekati
Rep Power: 13 |
Hi all,
I tried to manipulate the blockMeshDict, but I am not able to get rid of this problem. "inconsistent number of faces between block pairs 0 and 1" Can anyone help? blockMeshDict: FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (-1 39.8 -0.5) (81 39.8 -0.5) (-1 40.2 -0.5) (81 40.2 -0.5) (-1 39.8 1) (-1 39.8 52) (81 39.8 52) (81 39.8 1) (-1 40.2 1) (-1 40.2 52) (81 40.2 52) (81 40.2 1) (-1 81.2 1) (-1 81.2 52) (81 81.2 52) (81 81.2 1) (-1 -1.2 1) (-1 -1.2 52) (81 -1.2 52) (81 -1.2 1) ); blocks ( hex (0 4 7 1 2 8 11 3) (410 2 5) simpleGrading (1 1 1) hex (4 5 6 7 8 9 10 11) (410 2 170) simpleGrading (1 1 1) hex (8 9 10 11 12 13 14 15) (410 205 170) simpleGrading (1 1 1) hex (16 17 18 19 4 5 6 7) (410 205 170) simpleGrading (1 1 1) ); boundary ( bPlane { type patch; faces ( (0 4 7 1) ); } tPlane { type patch; faces ( (2 3 11 8) ); } fPlane { type patch; faces ( (0 2 8 4) ); } backPlane { type patch; faces ( (1 7 11 3) ); } lPlane { type patch; faces ( (0 1 3 2) ); } FPlane { type patch; faces ( (4 8 9 5) (8 12 13 9) (16 4 5 17) ); } BackPlane { type patch; faces ( (7 6 10 11) (10 14 15 11) (19 18 6 7) ); } LuPlane { type patch; faces ( (8 11 15 12) ); } LbPlane { type patch; faces ( (16 19 7 4) ); } RPlane { type patch; faces ( (5 6 10 9) (9 10 14 13) (17 18 6 5) ); } TuPlane { type patch; faces ( (12 15 14 13) ); } blPlane { type patch; faces ( (16 17 18 19) ); } ); ................ Thank You |
July 17, 2012, 10:07 |
Rep Power: 14 |
Could you post a drawing ? (about the geometry that you want to create with blockMesh)
July 17, 2012, 10:31 |
Deepak Cheekati
Rep Power: 13 |
PFA the image.Will this do?
July 17, 2012, 10:54 |
Rep Power: 14 |
Ok, this is the geometry that I had deduced with the points
The problem is in the syntax of blocks. The correct syntax is : Code:
hex (0 1 3 2 4 7 11 8) hex (4 7 11 8 5 6 10 9) hex (16 19 7 4 17 18 6 5) hex (8 11 15 12 9 10 14 13) |
July 17, 2012, 13:39 |
Deepak Cheekati
Rep Power: 13 |
Hi Rider,
Thank you very much Could you explain me how to number,so that I wont make this mistake again.. Thank You Turbulence. |
July 18, 2012, 02:35 |
Rep Power: 14 |
Hi Turbulence,
You will find the explanation of the rule to use (with illustration) on the following link: http://www.openfoam.org/docs/user/blockMesh.php Rider. |
July 18, 2012, 04:46 |
#9 |
Deepak Cheekati
Rep Power: 13 |
Thank you very much Rider
July 18, 2012, 05:01 |
#10 |
Rep Power: 14 |
Your welcome
November 26, 2019, 09:17 |
Inconsistent number of faces between block pair 0 and 1
#11 |
Sama
Rep Power: 7 |
I have same problem and dont know what is wrong with my mesh. I get error of "Inconsistent number of faces between block pair 0 and 1". Here is copy of my blockmesh dict:
FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // scale 1; vertices ( (-296 -296.6 -5000) (-296 -296.6 2192) (-296 -296.6 2792) (-296 -296.6 2992) (-296 296.6 2992) (-296 296.6 2792) (-296 396.6 2792) (-296 396.6 2192) (-296 296.6 2192) (-296 296.6 -5000) (296 -296.6 -5000) (296 -296.6 2192) (296 -296.6 2792) (296 -296.6 2992) (296 296.6 2992) (296 296.6 2792) (296 396.6 2792) (296 396.6 2192) (296 296.6 2192) (296 296.6 -5000) ); blocks ( hex (0 9 8 1 10 19 18 11) (16 16 194) simpleGrading (1 1 1) hex (1 8 5 2 11 18 15 12) (16 16 22) simpleGrading (1 1 1) hex (2 5 4 3 12 15 14 13) (16 16 5) simpleGrading (1 1 1) hex (8 7 6 5 18 17 16 15) (16 2 22) simpleGrading (1 1 1) ); edges ( ); boundary ( frontAndBack { type wall; faces ( (10 11 18 19) (11 12 15 18) (12 13 14 15) (18 15 16 17) (9 8 1 0) (8 5 2 1) (5 4 3 2) (7 6 5 8) ); } walls { type wall; faces ( (0 1 11 10) (1 2 12 11) (2 3 13 12) (15 14 4 5) (16 15 5 6) (18 17 7 8) (19 18 8 9) ); } outlet { type patch; faces ( (0 10 19 9) ); } inletone { type patch; faces ( (3 13 14 4) ); } inlettwo { type patch; faces ( (17 16 6 7) ); } ); Could you please help me how to solve this problem? Thanks alot! |
July 9, 2020, 10:52 |
Inconsistent number of specified cell
#12 |
George
Rep Power: 5 |
I am reviving this thread, since i found a problem that is not listed here. It could help somebody.
This errror can appear also if the number of specified cell in the same direction is different. In example: (50 10 1) (50 20 1) It is logical, but still i made it wrong the first time |
September 11, 2021, 10:33 |
same problem
#13 |
Pradeep Mamillapalli
Creating block offsets
Creating merge list --> FOAM FATAL ERROR: Inconsistent number of faces between block pair 0 and 1 From function void Foam::blockMesh::calcMergeInfo() in file blockMesh/blockMeshMerge.C at line 222. FOAM exiting blockMesh file convertToMeters 1; vertices ( (0 0 -0.01) //0 (0.1 0 -0.01) //1 (0.234 0.02127 -0.01) //2 (0.279 0.308 -0.01) //3 (0.659 0.308 -0.01) //4 (0.8545 0 -0.01) //5 (0 0.321 -0.01) //6 (0.1 0.321 -0.01) //7 (0.234 0.321 -0.01) //8 (0.279 0.321 -0.01) //9 (0.659 0.321 -0.01) //10 (0.8545 0.321 -0.01) //11 (0 0 0.01) //12 (0.1 0 0.01) //13 (0.234 0.02127 0.01) //14 (0.279 0.308 0.01) //15 (0.659 0.308 0.01) //16 (0.8545 0 0.01) //17 (0 0.321 0.01) //18 (0.1 0.321 0.01) //19 (0.234 0.321 0.01) //20 (0.279 0.321 0.01) //21 (0.659 0.321 0.01) //22 (0.8545 0.321 0.01) //23 ); blocks ( hex (0 1 7 6 12 13 19 18) (110 110 1) simpleGrading (1 1 1) hex (1 2 8 7 13 14 20 19) (110 456 1) simpleGrading (1 1 1) hex (2 3 9 8 14 15 21 20) (110 300 1) simpleGrading (1 1 1) hex (3 4 10 9 15 16 22 21) (110 1454 1) simpleGrading (1 1 1) hex (4 5 11 10 16 17 23 22) (110 718 1) simpleGrading (1 1 1) ); edges ( ); boundary ( inlet { type patch; faces ( (0 12 18 6) ); } outlet { type patch; faces ( (5 11 23 17) ); } bottom { type symmetryPlane; faces ( (0 1 13 12) ); } top { type patch; faces ( (6 18 19 7) (7 19 20 8) (8 20 21 9) (9 21 22 10) (10 22 23 11) ); } obstacle { type wall; faces ( (1 2 14 13) (2 3 15 14) (3 4 16 15) (4 5 17 16) ); } ); mergePatchPairs ( ); can anyone please address my problem? |
September 11, 2021, 10:42 |
#14 |
geometry attached here
January 31, 2023, 16:07 |
#15 |
Andrew Mills
Rep Power: 6 |
I know this is old but, the link is no longer working. Is there an updated link @rider???
Thanks! |
February 1, 2023, 02:51 |
#16 |
M
Rep Power: 12 |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 09:23 |
parallel run OpenFoam | Srinath Reddy | OpenFOAM Running, Solving & CFD | 13 | February 27, 2019 09:15 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 08:14 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
