[Technical] Creating 2D cartesian cut cell meshes
Old   May 15, 2014, 06:22
Default Creating 2D cartesian cut cell meshes
James Shaw
hertzsprung is on a distinguished road
I've just started using OpenFOAM to investigate atmospheric flow over terrain. I'm looking for suggestions on creating a cut cell mesh to model the terrain as a patch.
I already have code that adapts a regular grid produced by blockMesh to add a mountain using terrain following coordinates. I'm hoping to reuse the ground patch from this mesh in creating the cut cell mesh. Could snappyHexMesh be coaxed into producing such a mesh, or should I look at writing my own application?
hertzsprung is offline   Reply With Quote
Old   May 20, 2014, 17:03
James Shaw
This is as far as I've got with snappyHexMesh: http://goo.gl/GWUnSJ
I've created an .obj of the ground patch with writeMeshObj and used this as the surface with refinement level (0 0). Any suggestions are most welcome!
snappyhexmesh, two dimensional
[blockMesh] edges not aligned with or perpendicular to non-empty directions ynos OpenFOAM Meshing & Mesh Conversion 6 March 26, 2020 15:02
FvMatrix coefficients shrina OpenFOAM Running, Solving & CFD 10 October 3, 2013 14:38
Cartesian cut cell Cartesian cut-cell Main CFD Forum 0 February 26, 2007 18:21
How to cut cell? KtoTo Siemens 2 November 19, 2006 21:16
Help for cut cell scheme for moving problems Wei Main CFD Forum 0 August 2, 2006 09:32
