January 28, 2004, 16:00 |
Points
Hi
I want to read the points file using a code. I have multi blocks in my FOAM grid. I would like to know how these points are written in the file. I want to read these points using a FORTRAN code. Is this possible? |
January 28, 2004, 17:27 |
Do you want to read the point
Do you want to read the points from the blockMeshDict only (i.e. the block points) or the points from the generated mesh?
If the latter you can write a simple application to read the mesh and dump the points into a file with one coordinate per line so Fortran can easily read it. Something like (starting from an application which read a mesh) .. OFstream pointStream("points.txt"); forAll(mesh.points(), pointI) { const point& pt = mesh.points()[pointI]; pointStream << pt.x() << ' ' << pt.y() << ' ' << pt.z() << endl; } .. (if you want to read the block points that will be a bit harder. You'll have to read the blockMeshDict dictionary and dump the points as above) |
May 5, 2008, 12:57 |
Hi Mattijs,
is there a chan
Fabian Braennstroem
Rep Power: 19 |
Hi Mattijs,
is there a chance to do it vice versa, i.e. read two different point text files and create a points file for the polymesh? I would read a file like: fileName fileC= runTime.path()/runTime.constant()/"points2.txt"; IFstream CFile(fileC); double T1; double T2; double T3; while(0==CFile.eof() ) { if (0==CFile.eof()) { CFile >> T1 >> T2>> T3; Info << CFile.eof() << endl; } } but I get this: --> FOAM FATAL IO ERROR : Attempt to get back from bad stream file: /Software/OpenFOAM-1.4.1/tutorials_1.4.1/tutorials/simpleFoam/pitzDaily/constant /points2.txt at line 25014. From function void Istream::getBack(token& t) in file db/IOstreams/IOstreams/Istream.C at line 44. Once this would work, I would read a different points-file and assign newT1, newT2 and newT3. Afterwards the difference should be added to the existings points: diff1=T1-newT1 diff2=T2-newT2 diff3=T3-newT3 The difference could be added to the existing points by: pointField zeroPoints(mesh.points()); pointField newPoints = zeroPoints + scaleFactor*pInterp.interpolate(diff)().internalFi eld(); mesh.polyMesh::movePoints(newPoints); mesh.write(); where 'diff' is a somehow created vector. Would be nice, if you have (or anyone) some good hints :-) Thanks! Fabian |
May 6, 2008, 16:15 |
You are probably trying to rea
Mattijs Janssens
Rep Power: 26 |
You are probably trying to read 3 scalars from a last empty line.
Fix file or loop instead mesh.nPoints() times is my advice. |
May 7, 2008, 01:09 |
Oh, pretty simple with the loo
Fabian Braennstroem
Rep Power: 19 |
Oh, pretty simple with the loop over mesh.nPoints. Fixing the file my way did not help though. Thanks a lot!
Fabian |
May 7, 2008, 02:42 |
me again... actually I use thi
Fabian Braennstroem
Rep Power: 19 |
me again... actually I use this for reading the points2.txt file and the orig mesh. It works fine, but now the trouble is to combine the vector to a vectorField, which can be passed to the morphing:
fileName fileC= runTime.path()/runTime.constant()/"points2.txt"; IFstream CFile(fileC); scalar diff; vector diffv; vector T; double scale=1.0; forAll(mesh.points(), pointI) { CFile >> T; //read shape vectors const point& pt = mesh.points()[pointI]; //orig mesh pointStream << pt.x() << ' ' << pt.y() << ' ' << pt.z() << endl; //read orig mesh diff = pt.y()-T.component(1); diffv = pt - scale* T; // create diff between orig mesh and shape } Info << "Vektor T: "<< T << endl; Info << "Vektor T1: "<< T.component(1) << endl; Info << "Diff: "<< diff << endl; Info << "Diff-Vektor: "<< diffv << endl; Do you have a hint, how to append the vectors to a vectorField? Fabian |
May 7, 2008, 03:09 |
Read your new position into a
Mattijs Janssens
Rep Power: 26 |
Read your new position into a pointField first, then do your manipulation.
pointField newPoints(mesh.nPoints()); forAll(newPoints, pointI) { point& pt = newPoints[pointI]; CFile >> pt.x() >> pt.y() >>> pt.z(); } vectorField diffv = scale*(mesh.points()-newPoints); |
May 8, 2008, 15:19 |
Thanks a lot! Works nice :-)
Fabian Braennstroem
Rep Power: 19 |
Fabian |
[snappyHexMesh] .STL: non-closed manifold surface | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 32 | November 25, 2016 03:15 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
[DesignModeler] DM's JScript: FPoint()'s GetPoint(i) function picks points backwards? | ANT | ANSYS Meshing & Geometry | 2 | July 23, 2012 15:25 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
