[Technical] convert patch faces to internal faces? |
November 24, 2010, 20:57 |
Pei-Ying Hsieh
Rep Power: 18 |
In the boundary file, I have a patch, say called myInternal. Is there a way to convert all the faces in myInternal to internal faces? When I simply deleted this patch, I got an error. Thanks! Pei |
December 15, 2010, 03:48 |
Marta Lazzarin
I got the same error...I just would like to apply in OFoam the equivalent condition as 'interface' in Fluent.
Have you found a solution to this problem? Thanks a lot! Marta |
December 15, 2010, 08:36 |
Pei-Ying Hsieh
Rep Power: 18 |
Hi, Marta,
No, I still have not found a solution for this yet. Pei |
steadyUniversalMRFFoam Tutorial fails in MixingPlane | HenrikJohansson | OpenFOAM Bugs | 0 | February 14, 2019 04:48 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 07:48 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
